I need a Video Head for Matsushita VCR Model HS-B52
    Champion:
  • 236 Answers
Look for a parts unit (junker) on eBay. Replacement heads cost as much or more than a new recorder!
Posted on Nov 16, 2013
3 Suggested Answers
SOURCE: Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Posted on Sep 17, 2009
Grubhead
  • 5047 Answers
SOURCE: Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
Posted on Mar 10, 2010
TAPE KEEP SKIPING. CANNOT CONTROL TRACKING
Try cleaning the heads with Servisol Video 40. It's best to take the top cover off and give it a good clean. Use cotton buds, spray and wipe anywhere the tape comes into contact with. If that doesn't cure it you might have a worn video head.
Sep 28, 2010 | Mitsubishi HS-U447 VHS VCR
Mitsubishi HS-U57 vcr front display gets very dim!
Your front display is worn out, it has gotten gassy. Therefore the luminance level is low & the part is no longer available.
Nov 07, 2009 | Mitsubishi HS-U577 VCR
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Replace our VCR
I see someone selling that exact model on Ebay. Or there are many other Mitsubisha S-VHS similar in Model. I would stick with what you (they) are familiar with.
Hope that helps...
Geno
Apr 04, 2008 | Mitsubishi HS-U748 S-VHS VCR
Mitsubishi HS-U680 VCR
Here are the possibilities:
1. really dirty heads - both video and audio
2. TV is not selecting the right input for the VCR.
3. difficult (but rare) failure in the VCR output circuitry.
Hope Ya Fix it!
Jan 22, 2008 | Mitsubishi HS-U680 VHS VCR
DVD player /video cassette recorder
pull your head out of you *** and clean the heads
Dec 14, 2007 | Televison & Video
Bad recording from any source
The fact that both inputs give you a bad recording indicates its something common to both inputs. First thing I would do is try cleaning the heads. It's the cheapest solution to try. There is also an erase head as well, but that is usually not part of the video head. The erase head erases the tape just prior to the record head recording the new material on the tape. Problems in the erase head will cause you to see both what you just recorded and what was previously on the tape. The picture will be distorted and shifting back and forth between the new program and the previous one.
- Jim
Nov 29, 2007 | Mitsubishi HS-U560 VHS VCR
Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
