Yes. However they might not be your best solution. Portable air casters usually work best for very short distances and infrequent moves. This means that if you need more frequent moves or travelling longer distances, you will need continuous compressed air supply (high pressure nitrogen bottles), which would make the whole cost more than it's worth.
Whenever air is cooled it condensates (think of a cold beverage placed in a warmer environment), and there's nothing the manufacturer can do to prevent this (laws of physics). The manufacturer can place a heater inside the unit to dry up the condensate. I believe your problem is an inoperable internal heater.
Yes there is. First turn the unit OFF & unplug it. The remove the air intake filter and clean it. After that, remove the water collection bucket and was it in warm water and mild dish washing liquid. Rinse and thoroughly dry. Doing this should help to eliminate the odor.
According to the manufacture this unit never needs draining it vaporizes the liguid.
If it were to have a water tank it would be in the bottom of the unit and you can see the level in the tank, on models that have a tank they simply pull out and remove to be drained.
Product Description
The compact NanoMax AC takes up little room in the interior environment, and features the patented AutoDrain NanoMist Technology that vaporizes excess fluid build up, eliminating the need to drain the unit. The NanoMax AC has integral handle and casters for transporting unit, and long lasting washable filters. Offered in designer colors with remote control, this attractive appliance features outstanding industrial design that blends harmoniously with today interiors. Power Supply 115 V / 60Hz Power Consumption Range 680 - 830 Watts Current Range 6.8 - 7.9A Dehumidification Range 42 - 50 Pints/24H Refrigerant R22 Compressor Rotary 2 Fan Speeds 1-12 Hr Timer LED Screen Auto Shut Off Thermostat Range 62-90 Degrees F Dimensions - 12 W x 15 D x 30 H Weight - 50 lbs.
