Question about Datamax I-4308 Thermal Label Printer
Error message 'out of stock' I have tried re-calibrating, it is not successful, any ideas how I can fix this would be greatly appreciated
    Scholar:
    New Friend:
  • 52 Answers
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Posted on Apr 29, 2014
There might be a problem with some of the files on device
try using eject disk option when ever you want to remove you hard drive
Feb 05, 2013 | Computers & Internet
Out of stock
Morrisettepa: This error occur when the labels are not detected, 1. the label is out of sensor, 2. the label sensor is dirty or blocked. Clean it, adjust in correct position and perform a sensor calibration. Press and hold FEED button by 5-6 seconds and release it. In display you can see CALIBRATION SUCCESS, if not, then repeat the quick calibration.
Sep 15, 2011 | Datamax DMX-I-4208 Label Printer
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Datamax prints ten or so labels then skips one (leaves it blank) then continues on
First check the sensor is free of any label debris. Then follow instructions below:
Standard Calibration is appropriate for most media types. During the process, the printhead assembly can be raised for visual access to the media and media sensor. In addition, displayed sensor readings can be used to indicate the best position over the media, which is helpful when using small, position-critical TOF notches or marks.
Three readings are required:
.No Media
.Lable Backing
.Backing plus lable
Step Operator Action Displayed Message Comment
5 Press the key. SENSOR CALIBRATION
PERFORM CALIBRATION
You are beginning the standard
calibration procedure.
6 Press the key.
Remove the media from the
Media Sensor then press any
key.
REMOVE LABEL STOCK
PRESS ANY KEY <yyy>
This sets the parameter for the
'empty' value.
Where 'yyy' is a numerical
value representing the current
sensor reading.
7 Proceed according to your
media type:
Die-cut stock: strip the media
from the backing and then
reinsert it into the sensor; adjust
the Sensor Eye Mark over the
center of the backing.
Notched stock: adjust the
center of the notch.
Reflective stock: Adjust the
center of the facedown black
mark.
Continuous stock: go to Step
8.
Press any key to continue.
SCAN BACKING
PRESS ANY KEY <yyy>
Or, for reflective media:
SCAN MARK
PRESS ANY KEY <yyy>
'gap' or 'mark' value.
sensor reading: useful in
locating the best sensor
position.
ã Note: Never position the
sensor over a perforation when
recording a sensor reading.
ã Note: Do not move the position of the Media Sensor after it has been adjusted.
8 Position the label (and backing,
if any) under the Sensor Eye
Mark.
ã Note: If using preprinted
media, ensure the label area
under the sensor is free of
preprinted text, graphics or
borders.
SCAN PAPER
PRESS ANY KEY <yyy>
'paper' value.
sensor reading.
Maintenance and Adjustments
5-3
Standard Calibration (continued)
9 Observe the display. GAP MODE
CALIBRATION COMPLETE
REFLECTIVE MODE
Or, for continuous media:
CONTINUOUS MODE
The calibration was successful.
See note below if another
message was displayed.
10 Exit upon successful
calibration: Back out of the
menu tree by repeatedly
pressing the key.
If using gap or reflective media,
press and hold the FEED key.
The printer will begin
advancing media; allow at least
one label gap (or mark) to
advance under the sensor.
READY
The printer is now ready to
begin printing.
Aug 09, 2011 | Datamax DMX-I-4208 Label Printer
I download XP driver for N1240U from Canon. Everything seems to work including successful diagnostics check. But, when I try to scan using Toolbox, I get a TWAIN error message. My file system is NTFS....
scan with adob photoshop /import - from - your scaner device/ , it will be correctly, maybe toolbox not working normally, if with photoshop will not be resaults, in control panel \ in scaner and imaging devices see is there your scanner, if it will not be in there, reinstall driver.
Jun 01, 2011 | Canon CanoScan N1240U Flatbed Scanner
Zebra 140xi111 plus printer printed my labels fine, then I switched to a duralabel with the same dimensions and now it skips a few and then I get an error message saying the paper is out...is there a...
Hello aperkins308,
I am with DuraLabel Tech Support and your printer does need to be calibrated for the stock you have loaded. All DuraLabel printers come with free lifetime tech support so please give us a call at 1-800-788-5572 or send us an email at support@graphicproducts.com
Nov 18, 2009 | Zebra Printer 140-751-00000
Dvd-r wont burn error message says "power calibration area error - medium error"....it used to work because i have burned many dvd -r sony discs. but all of a sudden it just quit i have been trying to fix...
Have you started a new batch of discs?
This error could you get when the drive and disc are not compatible.
So please look for new firmware for your drive or try another brand of discs.
Sep 19, 2009 | Acer Aspire™ T180 PC Desktop
Hi please help i have a lexmark 1200 printer and when i print it very pinky i have not got book
When I try to install my Epson Stylus SX115 printer driver an error message tells me that file E_DMA130.DLL is missing have tried to locate this file without success! any ideas would be appreciated!!
Aug 15, 2008 | Office Equipment & Supplies
Sony slimline ps2 NO DATA
the ps2 slim gets disc read error alot. this issue can be fix by replacing the laser in the system. make sure you get the correct laser
Nov 03, 2007 | Microsoft Xbox 360 Console
Datamax I-4308 Thermal Label Printer Logo
87 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
