MC 9100 Scanner not beeping
Form has 2 fields that we Scan a differnt bar code too. The gun will beep after the first code is scanned, but does not beep when we scan the second
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
SOURCE: LS2208 beeps to ignolage the scan but puts no information
I don't know if this applies to the LS22208.
Symbol Support FAQ says;
A slow continuous flashing LED on the LS9208 indicates that the LS9208 has been put into “programming mode” and is ready to scan programming bar codes. Once the LS9208 is correctly programmed, the LED should stop flashing and remain on, indicating that the scanner is ready for use.
A fast, continuously flashing LED on the LS9208 indicates an internal problem. When the LED is in this state, the LS9208 laser is also shut off for regulatory reasons.
We support these for some big retailers. When they call with that issue 99/100 it's reseat the cable from the base of the scanner (or the system if accesible), no re-programming).
Posted on Jan 16, 2009
  • 74 Answers
SOURCE: I just got an LS4006i scanner with a ps2
The cable has to have a PS/2 keyboard connected to it and you must be connected to the keyboard port. Unfortunately this scanner did not support "Notebook" mode where you could make it think it was connected to a laptop and leave the keyboard connection open. The other thing to check is that the "IBM PC/AT" barcode is scanned from Adobe page 55 of 182 of the LS400Xi Product Reference Guide.
Posted on Nov 20, 2009
Yogger
  • 117 Answers
SOURCE: Symbol Model LS 9208, Bar
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Posted on Nov 02, 2010
Yogger
  • 117 Answers
SOURCE: Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Posted on Dec 07, 2010
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
Problem with scanner
I have it connected to keyboard port as they instructed.
Sep 02, 2007 | HHP 3800 (015305) Handheld
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
