Question about Irons
Tefal Instructions - Irons
Tefal quick cup , no water coming out....still a little steam and orange light on...any idea what the problem could be please
Have you cleaned it lately with vinager? Sometimes you have to run it through it to remove the deposited from hard water. It happens to coffee makes an all appliances that use water. Find your instructions an follow what is recommended. If you don't have them you can look them up online.
Jul 19, 2017 | Tefal Irons
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
I need descaling instructions for Tefal Ultraglide easycord55...Mislaid instruction booklet....Thank you
thank you solved de scale instructions for Tefal Ultraglide easycord 55, found manual on net....
Jan 09, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Tefal iron
Download from here:
http://www.tefal.co.uk/NR/rdonlyres/80AA54F2-1ED6-403C-8590-9E680E3A0288/0/TEF_TurboPro.pdf
If this works please rate fixya, many thanks.
Apr 11, 2009 | Irons
How to use the self clean feature on a tefal steam iron
I cleaned mine with alcohol and clean terry cloth. Took some work but it eventually got clean.
Dec 24, 2008 | Irons
Irons Logo
23 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
