I cant get the correct color settings on my vizio vo22l fhdtv 10a
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
Set its settings to default. In default settings, the color might be a little more than normal. Reduce it.
Posted on Oct 22, 2013
ButtFuzz
  • 463 Answers
SOURCE: vizio 42" fhdtv - need help for better picture quality settings
Since you're using "analog cable", I would adjust the television such that the picture is not streched. This means there will be black bars to the left/right of the 4:3 picture, but you should experience some improvement in picture quality because the TV is not trying to interpolate what to do with an already crappy analog cable signal.
You may also want to add a signal booster where the cable first enters your residence... often, folks split that analog signal up so much it is weak... and looks much like you describe.
Posted on Mar 09, 2009
alpug
  • 1961 Answers
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Posted on Jun 03, 2010
Testimonial: "Thanks again. :)"
budmrtn
  • 11361 Answers
SOURCE: Have a Vizio VW42L FHDTV 10A HD,working ok but I
Can you post pictures or send them to me? budmrtn@aol.com
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Posted on Jun 17, 2010
SOURCE: tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Posted on Jul 19, 2010
TV #1
  • 129 Answers
SOURCE: no sound from pc to tv for Vizio VO22L
Sound cable needs to be plug from the computer to the TV
Posted on Nov 01, 2010
I get a message that says "No Signal"
Tuner fault or the Ariel connection is not correct.
Gopakumar Gopalan Google
Jun 26, 2015 | Vizio VO22L 22 in. LCD TV
I have no power in my Vizio VO22L LCD TV. I replaced the power board and still nothing. The Vizio logo in the front does not light up when plugged in. What else can it be. One expert said the cable or...
you have to make sure voltage is getting to the Power supply board, if you know how to check for the 110-120v ac at the board and that there is no line fuse in between. If you are getting power at board then I would make sure the PS are good. You also can check to see if you have voltages going to other boards, Inverter boards go bad in this set alot, but you should still have logo light up white or amber, To get it right you must check voltages, carefully.
Jan 19, 2011 | Vizio VO22L 22 in. LCD TV
No sound from pc to tv for Vizio VO22L
Nov 01, 2010 | Vizio VO22L 22 in. LCD TV
My vizio gv42l fhdtv 10a picture flickers like a strobe light, on every input. had the tv since 08. inverter board? main board? Thanks Robert
Jun 03, 2010 | Vizio GV42L 42 in. LCD Television
One channel has no sound but another tv works fine
your set is in the SAP mode go into the cutomer settings and locat the sound setting and turn it to stereo
Nov 19, 2009 | Vizio VO22L 22 in. LCD TV
Screen goes blank after about 5 minutes of operation
power up to black backlit screen but won't go beyond that . I have to unplug the TV to turn it off...Power board seems OK. Vizio VU42L FHDTV 10A
Sep 08, 2009 | Vizio Televison & Video
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
Vizio 42" fhdtv - need help for better picture quality settings
Mar 09, 2009 | Vizio VW42LF 42 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
