Question about Homedics SC400 Glass LCD Digital Scale
I love my scale, but I need to change the batteries every 2 weeks. I'm using Enercell batteries CR2032 or Duracell batteries CR2032. Shouldn't the batteries last a little longer? Is there a different brand battery I should be using?
I changed the battery to the right one which is CR2032 and put it in and all that comes up on scale is ERRL will not go to 00. Thank You.
CR2032 batteries are light use and I am pretty sure only preserving the memory of the scales, which usually have an MN1500 9 volt battery.
Google
make model manual
Mar 19, 2018 | The Health & Beauty
Need # for replacement battery, please
Many Taylor scales use one or two CR2025 or CR2032 batteties.
I usually put in the higher current CR2032. These are available online, shopping centers, pharmacies, and even grocery stores. If you Google your part number and manufacture you can download the manuel which will tell you the battery required.
May 09, 2016 | Taylor 7321 400 Pound Lithium Scale
HOW DO I CHANGE BATTERIES IN OZERI BATHROOM SCALE MODEL ZB13
On the back of the scales under the Ozeri sticker, you will find the battery cover. Remove the cover and replace the two CR2032 batteries (model ZB13).
Sep 04, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
Salter scale
Maybe those battery contacts are not making good contact with the batteries, or the contacts are dirty with corrosion. You can clean them with rubing alchol.
May 23, 2014 | Health & Beauty
Replacement battery for 5786 taylor scale
Fixya does not sell replacement batteries.
Dec 23, 2012 | Taylor Health & Beauty
Taylor 7558 scale not working even with new batteries
the above answers are correct and need to be done but make sure the batteries are CR2032 and NOT CR2032E batteries. My Taylor 7901 scale finally works! Thanks for the advice. I love fixya.com because they always have the correct answers!!!!
Sep 12, 2012 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
Cmos problem: always reset cmos everytime unplug the power cord , but as long as it unplug, it wont reset. change the battery, recheck every cord, reset cmos, check jumper position as manual, done but...
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 21, 2011 | ASUS P5P43TD Core 2 Quad/ Intel P43/ DDR3/...
New CR2032 battery last about 1 week before the scales say that the battery is dead. Have tried lots of different battery brands and the same happens with all. We only use the scales a couple of times a...
Sounds like the scales have developed a leak across the battery and is draining the power. New scales maybe the best option but before that, have a look to see if there is any spilliage around the pcboard and/or battery terminals.
Jan 03, 2011 | Microwave Ovens
Homedics SC400 Glass LCD Digital Scale Logo
70 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
