Question about Motorola Computers & Internet
Tech 2 scanner
MC 9100, When scanning a bar code the gun beeps for the first field, when I can a second code for the same for it does not Beep.
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Posted on Jan 20, 2015
SOURCE: the scanners won't scan information after being programmed
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Posted on Jul 06, 2007
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
tommya300
  • 724 Answers
SOURCE: Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Posted on Jul 27, 2009
  • 74 Answers
SOURCE: 3 Beeps after trying to scan
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Posted on Oct 09, 2009
Testimonial: "you are AWESOME! that was exactly the problem. thanks man!"
  • 74 Answers
SOURCE: 4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Posted on Oct 23, 2009
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Manual carriage return necessary after scanning barcode
With the Symbol scanners, they usually come with a sheet at least of scan codes to configure the scanner. One of those bar codes will have the option of not needing to manually hit the carriage return. What model scanners are they? You can probably find the codes from Symbol.
Sep 17, 2009 | Symbol LS 2208 Barcode Scanner
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
Need my p470 symbol scanner to auto enter
It depends on whether you are using a keyboard wedge or a serial connection. Use 123Scan or MCL to make a change to the ADF file that tells the scanner what to do. Then you will have to upload the file to the scanner.
Appending an "Enter" to a scanned bar code
(Keyboard Wedge connection)
Scanned bar code data 04843100Criteria 1 Code type = Any
Criteria 2 Code Length = Any Length
Action 1 Send all that remains Action 2 Send Value Keycode = 7013 <Enter> (String field must be empty)
Output after ADF rule 04843100<Enter>
Note: To have an ADF rule applied to all scanned bar codes, leave the criteria unspecified (Code Type = Any and Code Length = Any Length).
Appending a "Carriage Return Line Feed" to a scanned bar code
(serial connection)
Action 2 Send Value String = \0D\0A
Note: Keycode value is ignored when string field is populated.
Output after ADF rule 04843100<Carriage Return Line Feed>
Dec 25, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
