Question about Garden
Glidermatic gts 2000 keeps beeping - Garden
2 Suggested Answers
SOURCE: Hi, My glidermatic gts keeps going
The Glidermatic GTS 2000 has limits that are stored electronically.
The problem you have is the closing limit is set too low and needs to be adjusted so the door is just resting on the concrete - currently it is trying to drive through the concrete, the motor detects and obstruction and reverses.
If your Glidermatic GTS 2000 was supplied & fitted prior to April 2010 you can download the 'Limit Setting' procedure on the Gliderol website. If the unit was installed after April 2010 it MAY have a revised PCB known as the NGTSv2 PCB. Contact your local branch for limit setting procedures as they are not yet available to download online.
The combination of a mechanical door and electric motor means periodical adjustment is required to esnsure the travel limits and - most importantly - the sensitivity is set correctly. A service to your DOOR is strongly recommended every 12 months.
I hope this helps
Posted on Mar 08, 2011
How to lower automatic gliderol gts 2000 garage door
check that the controls are not reversed by pressing the opposite button to the direction you want
Apr 05, 2015 | Garden
WHEN WAS THE TOPCON GTS 811A MADE
The GTS 81X series a breif window between the GTS 8XX and the GTS 9 series. The 81X's were discontinued approximately 2005ish when the GPT/GTS 9 series came out, so it would be older than that. But i wouldnt go back as far as the 90's. Hope that helps
Mar 17, 2013 | Topcon Gts-811 / Gts-812 / Gts-813 /...
My 2000 celica gts won't start when it is really
A no-start condition can occur with several different symptoms. Have a clear understanding of which one applies to your vehicle when having the problem diagnosed.
Here are the most common symptoms:
  • Engine will not turn over (or crank over)
  • Engine will turn over (crank) but will not start
  • Engine starts and dies (stalls)
Nov 14, 2012 | Cars & Trucks
00 celica gts timing chain problems
The timing chain should not routinely need changing, but perhaps the tensioner does.
Try first to eliminate any other causes, like the bearings in the fan, drive belt idlers, or alternator. A useful tool is a long screwdriver which you can apply to the various areas while placing your ear to the top of it while the motor idles.
Be very careful to keep clear of moving parts like fan blades.
Apr 11, 2012 | 2000 Toyota Celica
2000 toyota celica GTS shift mode light keeps flashing and check engine is on.
you have blown your red line check gaskets from throttlebody gasket directly to the front of the intake. while running motor spray some brake cleaner around the areas one leak and you hear the automatic change in sound of motor. replace and torge to specs. 11_21_2011_9_10_52_pm.jpg
Sep 02, 2011 | 2000 Toyota Celica
Hi, My glidermatic gts keeps going open once it reaches the bottom, everything works; it?s just it keeps going open. I have to close open, close open until it stops in the close...
I hope this helps
Jan 03, 2011 | Garden
WHEB TO CHANGE A TIMING BELT FOR A 2000 TOYOTA
Never as it does not have a timing belt but instead has a timing chain that requires no maintenance and should last the life of the engine.
Apr 28, 2010 | 2000 Toyota Celica
Toyota Celica gts 2000 blowing cold air when heater is on.
nothing try back flushing heater core, they clog up due to litle water preasure,you might want to flush cooling system if you already havent, hope this hleps.
Oct 06, 2009 | 2000 Toyota Celica
2000 CELICA GTS DRL WONT GO OFF EVEN WHEN ENGINE IS TURNED OFF
try replacing the relay for the daytime running lights
Jul 14, 2009 | 1997 Jeep Grand Cherokee
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
