Question about Trendnet 56K USB INTERNET MODEM PHONEAND FAX FUNCTIONALITY - TFM-561U
Trendnet trm-561u only sends one fax sheet then stops working. After I reboot my computer it will send one more page then stop working. Any Ideas?
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Will not fax but will receive
Sounds like you are faxing multiple pages through the document feeder and it is trying to grab a few sheets instead of just one.
If you are doing multiple pages make sure they are aligned and separated.
Maybe fan the pages and then pat them on a level surface to make sure they are aligned.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Faxjet 525 will not send faxes
it is never getting a dial-tone. Phone line should be plugged into the LINE port.
Jan 28, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Keeps printing pg 1... sender's machine says it isn't going thru
Press
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for the machine to reboot
Jan 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Fax takes too long to send.
any chance of putting it in a zip file to transmit it faster
Apr 25, 2017 | Conexant (56KUSBMODEM)
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Confirmation Page
Function 74 set 12 set 2 set stop.
Aug 27, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Paper feeding when printing recieved faxes
If this is primarily happening with receipts from one sending fax machine, the most likely cause is that the sending machine is transmitting an end code that causes this page to print.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Oct 26, 2007 | Canon FAX-JX200
Trendnet 56K USB INTERNET MODEM PHONEAND FAX FUNCTIONALITY - TFM-561U Logo
20 people viewed this question
Top Trendnet Computers & Internet Experts
David Payne
David Payne
youbrokeit
Level 1 Expert
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
