Sears 11/2 ton floor jack
Oil leaking around piston while pumping up jack
  • 27 Answers
Is there anywhere that you can tighten the seal retainer if not needs a new seal . My experience is that a seal kit is as expensive as buying a new jack plus the work that goes into it. Look up how much to buy a new one and a set of seals then decide
Posted on Oct 21, 2013
2 Suggested Answers
  • 1937 Answers
SOURCE: MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Posted on Oct 17, 2009
Testimonial: "All the reference sites are very helpful and a time saver, so thank you! Now on to my further repair homework to solve all the mysteries of machinery."
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
How to change oil pump
well you got the cat by the tail
well jack your car and block it
take the engine motor mount bolts out
very carefully use a 4x4 and a floor jack and jack the motor from the front using the
damper pulley you do-nt need to jack it up very far
take out all the oil pan bolts once the bolts are out you will have to pry the pan loose
once you get the pan out remove the oil pump and scrape all the old gaskets out
and the pan clean the pan very well and paint it blue so you can see any leak you
might have when you reinstall the pan
now before you put the gaskets in use permatex (BLACK) it works well around oil
reinstall the oil pump reinstall the pan once all this is finished put the motor mount
bolts back in and out your car back on the ground and fill with oil finished
rember to check every now and then for leaks hope this helps you bob
May 02, 2011 | 2001 Ford Escape
I have a Pro-lift floor jack - model #F-388P - (2-1/4 ton, 4500 lbs). It is leaking hydraulic fluid where it compresses the fluid (where the piston compresses the fluid - the gaskets leak). Can you...
Try here - this is the PDF for one of their jacks, but contact info is on lower right side
http://www.shinnfuamerica.com/Temp/831.pdf
Mar 09, 2011 | Garden
I have a150 psi compresor that is 5 years old. it currently does not reach 150 psi without running for a very long time and sometimes just stays at 120 psi and wont get any higher ( the motor just keeps...
Repair all leaks to get true test of condition of cylinder / piston ring and check/reed valves. It is reccommended to know amount of time to fill tank when new and compare this time to present. Filling time is indication of wear. Another method to discover wear is to remove cover to pump and examine condition of cylinder wall close to top of cylinder (on oil-less models). If you see scratches on cylinder, air is leaking past piston seal. On pumps that use oil, very hot discharge air hose or pump head is indication of leaking valves or head gasket. Sears usually has good prices on replacement parts. Good holidays
Dec 08, 2010 | Craftsman Air Tools & Compressors
Jacks stalls 1/2 way up
try opening the hydrolic oil "fill" plug to let air in...Your jack came with a vented plug,for you to put on after shipping...so oil doesn't leak while being transported...I hope this helps,...1nglen
May 04, 2009 | Plumbing
Sears model # 875.501390 floor jack will not raise at all.
IT SOUNDS LIKE IT IS CAPABLE OF MOVING FLUID FROM THE RESERVOIR TO THE CYLINDER. CAN YOU SEE THE SMALL PUMP PISTON POP BACK OUT WHEN PUMPING THE HANDLE? MOST JACK PROBLEMS BELIEVE IT NOT IS AIR. THEY GET AIR POCKETS IN THEM AND CANT PUMP THEM OUT. TRY REMOVING THE FILL PLUG ( TYPICALLY A SMALL RUBBER POP-IN CAP ) FROM THE CYLINDER AND JACK IT UP. IF THIS WORKS DO IT FEW TIMES, THEN REINSTALL THE PLUG. YOU COULD ALSO HAVE A SMALL CHECK VALVE PROBLEM INSIDE. IF YOU DISASSEMBLE, BEWARE OF SMALL SPRINGS AND CHECK BALLS. MAKE NOTES. HOPE THIS HELPS.
Apr 06, 2009 | Plumbing
Floor jack will not raise even without load
sounds like either pump piston seals or check valve on pump.
Apr 02, 2009 | Plumbing
Hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Mar 01, 2009 | Plumbing
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
