Olevia 232 Why is there a 2 inch wide bar across screen & its stuck on on Channel. Cannot change the channel.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Some power supply voltages are missing from the main power supply regulator board. It will be best to contact any service technican.
Posted on Oct 22, 2013
TVtechmaniac
  • 140 Answers
SOURCE: Big black screen in picture
You have the CC (closed captioning) turned on and it is set to text mode. Look for a button on your remote labeled "CC" or go into your TV menu and make sure the captioning selection is set to "off".
Posted on Sep 19, 2007
ginko
  • 19396 Answers
SOURCE: TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
Posted on May 16, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
  • 8457 Answers
SOURCE: their are vertical lines going across the screen
No,U just have a weak signal that all,U use free air right?Get a out door antena or get digital antena,better reception and signal.
Posted on Sep 22, 2009
pabloloco
  • 2335 Answers
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Posted on Dec 26, 2009
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
Green line appearing on screen
Being that the tv is still under warranty. Do not waste another second. Have it sent in and repaired under warranty. If not the problem could get worse and then you have to fit the whole repair bill.
Thank you,
Lee
Sep 08, 2009 | Olevia LT32HVM 32 in. LCD Television
Olevia 237V S11 Firmware
for all firmware updates you must go to this site http://www.olevia.com/en-us/Support/Firmware.aspx
and follow the directions...............(note you must have a blank usb flash drive)
Jun 20, 2009 | Syntax Olevia 537H Television
No tv signal on my olevia 232-s12
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
Channel Search
With remote, hit MENU, (use up/down arrows) & scroll to SETUP. Hit ENTER & scroll to TV. Hit ENTER & scroll to AUTO CHANNEL SEARCH. Hit ENTER & scroll to CABLE. Hit ENTER & scroll to AUTO. Hit ENTER, wait as it scans (about 5 min). Your done.
Jun 18, 2009 | Televison & Video
My Olevia TV will not change channels using the remote or buttons on the TV. When I push the channel up or down button, the tv mutes. It will change to 1 channel using the return button. I have tried...
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Apr 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Crawling lines on lcd 42 inch
that sounds like a power supply problem check your filter caps in the power supply they are leaking.theyare not filtering the voltage properly.if you are not a tech kindly have one look at your set
good luck
Apr 07, 2008 | Vizio L32 32 in. LCD HDTV
AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
Jan 10, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia 232 hd tv remote codes
this code dd not work with my remote for the olevia 232v..
maybe i will just buy a new remote for $29.00 and be done with it...; > (
Dec 07, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
