Computers & Internet Logo
Posted on Oct 21, 2013
Where can i download a driver?
Where can i download a driver of Meditech 6200a AGP8x DDR2 for Win XP
Dave C
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Oct 21, 2013
Dave C
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
1283
Points
32
That is nVidia chipset based graphics. If it is integrated onto a motherboard then the nForce motherboard chipset drivers should include the basic driver.
A more current, chipset specific driver for XP is here:
http://www.nvidia.com/download/driverResults.aspx/57493/en-us
3helpful
Meditech 6200a AGP8x ddr2 driver?
Step 1: Integrated Motherboard Graphics
Step 2: AMD 6-Series Chipsets
Step 3: All 6-Series Chipsets
Step 4: Select current operating system
Press "display restults" button
3helpful
Winfast A340 agp8x driver for win7
Sorry, but I don't think this card is supported beyond Win XP SP3.
8helpful
2answers
I need a driver for my acer aspire m1640
Download Acer Aspire M1640 Chipset & AHCI SATA Driver For Windows XP Description: Intel Chipset and AHCI SATA Controller for Win XP
Download: Chipset-and-AHCI.zip
Download Acer Aspire M1640 Audio Driver For Windows XP Description: Audio Driver for Win XP
Download: Audio.zip
Download Acer Aspire M1640 Network Driver For Windows XP Description: Wireless WLAN Wifi, Modem and Ethernet Lan Card Driver Package For Win XP
Download:Wireless-Modem-Lan.zip
Download Acer Aspire M1640 ATI Graphics Display Driver For Windows XP Description: ATI VGA Graphics Display Driver For Win XP
Download: Part1: ATI.rar.part1 Part2:ATI.rar.part2 (Download both parts and extract using winrar)
Download Acer Aspire M1640 Nvidia Graphics Display Driver For Windows XP Description: Nvidia Geforce 7050 VGA Graphics Display Driver For XP
Download: NVidia.zip
I hope this information will be helpful. Thank you for using FixYa!
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Problem with my GeForce 6200a graphic card
the driver cause this so go to the below link and download the driver, befour installation go to ur contro panel and remove ur old driver then restart,
then install the new driver and reboot again,
this should solve the problem
link :
http://www.nvidia.com/content/DriverDownload/download_confirmation.asp?kw=&url=http://us.download.nvidia.com/Windows/181.22/181.22_geforce_winxp_32bit_english_whql.exe
My cd of graphic gf 6200a is lose
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
About toshiba satellite L30-c330
If you don't have the original drivers; check in toshiba.com or download.com.
About the upgrade: check your manual to know with type of memory your laptop needs (yours is DDR2) , after that you can put any size from 512MB an up. Your Laptop can holds only 2 simms, so try to get the max of memory you want.
Grand Canyon Tech
Grand Canyon Tech
