My honeywell cm900 thermostat keeps showing the tempreture as -24 degrees, therefore it keeps working on full power in order to bring the tempreture back up
  • 400 Answers
I would change the battery first. Then try adjusting the temperature to see if that has any affect. From here I would guess the temp sensing thermistor is open or short, causing it to indicate the extreme temperature of it's capability. Test the thermistor and replace, or replacing the thermostat are the only solutions. I hope this helps.
Posted on Oct 22, 2013
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
DT92E room stat appears to be very inacurate with its room tempreture, our normal room temp is about 22c we have to set the stat at 25c to get heat and the stat cuts out after a temp rise of 1c
All thermostat is calibrated @ difference of 2 degree.to cut in and cut off.
In heat mode, if you keep 25 and your room temp 23. it will start at the end of 24 or beginning of 25 degree.Cut off also @27 degree beginning. Please check Tips & how to do's in Fixya
Jan 11, 2011 | Honeywell Heating & Cooling
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Thermostat
I have a Honeywell Programmable Thermostat, T8011R. The users guide for the T8000 series can be found at:
http://www.honeywell.com.au/business/acs/acp/ecc/ec/residential/identify.html
To keep your temperature at a single setting, just enter the temperature at every period, i.e. WAKE, LEAVE, RETURN AND SLEEP for both the Monday through Friday time frame and the same for the weekend. I do this at 55 degrees when I'm going to be out of town.
To 'Guest' , enter your 68 degrees at WAKE, LEAVE and RETURN, then enter 66 degrees at SLEEP. Do this for the Monday through Friday time frame and again for the Saturday - Sunday time frame.
Dec 19, 2007 | Honeywell Programmable Thermostat Heater
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
