Question about Canon Office Equipment & Supplies
Canon iR2018 is not recognized by Windows 7 on USB port, network print job is sent to printer, printer is starting to print but no document is printed out, with no error on the printer even on PC - any idea ? (except faulty ports)
Inky
  • 691 Answers
SOURCE: usb printer problem "port in use please wait"
Can you advise which operating system you are using? Assuming 32bit windows: Unplug the printer from the USB and try deleting the printer from the printers folder. Then download the latest driver from the Canon web site. Once you have you have it, in the control panel go to SYSTEM and into HARDWARE tab and then DEVICE MANAGER. Look under UNIVESAL SERIAL BUS CONTROLLERS and check that there are NO yellow symbols. If there are yellow symbols you need to remove the offending item from the list (making a note of it's description) and then reboot your machine. When it comes back up it should advise that new hardware has been found and go through the process of installing the drivers. You can now go the manufacturers web site and download the USB controller driver for your device. If the file is a zip extract it to a folder on your PC. When it asks if it can go online to find a suitable driver, let it do so and you can also specify a location for it look (where you extracted the download above) Once it finds the driver required and has finished installing it, reboot your system and then install the printer driver you just downloaded. Hopefully this will get you back on the go. If you have a windows 64 bit system I'm afraid you are on your own. 64 bit drivers that work are very hard to come by. Let us know if this is any use to you, if not we may more to offer.
Posted on Sep 16, 2007
SOURCE: Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Posted on Mar 26, 2009
gunninfo
  • 59 Answers
SOURCE: Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
SOURCE: canon ir2016 TROUBLESHOOT printer problem
Hi mate,
Prior to the issue you facing currently seem like ,
1)have u put the printer driver as default.
2)have u point to the correct printer port at the driver.
3)at the driver advance setting ;get the device status then reboot the machine .
GOOD LUCK MATE......Kindly RATE ME!!! Thanks YOU.
Posted on Sep 26, 2009
SOURCE: Printer connected to a Asus
I'm having the same issue with the same router and printer (mine is CLP-300/XXA).
At first when I try t print a pdf file or an image or any text/word document file with pictures/images I get an SPL-C error.
I have upgraded the firmware and it worked great on my laptop! Then, I tried to install the printer driver on my desktop, but now none of them work correctly.
Still not solved, but here are some suggestions:
1. Try to upgrade the firmware. 2. Try to install the original samsung printer driver 3.0.1
3. If it didn't work try to install the updated driver 3.0.4 4. If it didn't work try to install the Universal Printer Driver
5. IMPORTANT: between uninstalling and installing driver, disconnect both printer and router A/C power adapter and try to reboot you PC after removing the previous driver!
I'm going to work on it and see if it works. The DD-WRT firmware solved the exact same problem on my previous RT-N13U router, but unfortunately DD-WRT doesn't support RT-N56U yet!
Note: I called ASUS and they told me that Samsung printers are not supported for printer sharing server :(
Posted on Jun 27, 2011
Can i hook up my printer to my wireless router and if i can how do i tell it to print when i need it to print
The iP6310D can't connect to the wireless router directly. It has a USB port and an optional blue-tooth receiver.
If you connect the printer to one computer, you may be able to share it using that computer as a server. Install the printer software on all of the machines. For the software, see http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip6310d#DriversAndSoftware . For Windows 7 and 8, if you set up a Homegroup, enable sharing for the printer on the computer that it is directly connected to. Then use Add a Printer command from the Devices and Printers Control Panel option to locate networked printers. For other OS options, you'll need to make sure that the computers are in the same workgroup. (See the Network set-up information.) Then add a network printer.
If your wireless router has a USB port, you may be able to connect the printer to the router. Again install the printer software on each computer. Then use the router's software to add a printer on the computer. (For Linksys routers, that is the Cisco Connect software. Some routers may not offer this software for all OS's or for all printers.)
A similar option is a print server connected to the USB port of the printer. You will need to check the specifications for each one. There are some that only work on select printers.
Once the software (the printer driver and then the network software/shared printer is set up), then any program should be able to print following the File > Print command.
Please add a comment with your OS and/or router model, I'll try to walk you through setting up a shared printer or a USB connection on the router.
(Note: I have a USB printer connected and a wired network printer to a Cisco router. My only issue is that I get a printer error with every print job. The printers print the documents anyway. The error is due to the printers not responding to the software as fast as if it were a direct connection.)
Aug 10, 2013 | Canon PIXMA iP6310D InkJet Photo Printer
When I upgraded to Windows 7 yesterday, my Canon laser multifuncition printer doesn't print. It shows up as an "unknown device" in the device manager which lists it as a...
Don't believe everything they say as Windows 7 does have some bugs to be worked out. Take out the printer program completely and then download the program with windows 7. Windows update should fix that for you by plugging in the device after you take it out. You can download the correct driver from the canon site if needed.
Jan 03, 2011 | Canon Office Equipment & Supplies
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
Steps to configure Canon IR2018 printer in network using network port of the printer
steps to configure Canon IR2018 printer in network using network port of the printer
Oct 26, 2010 | Canon Office Equipment & Supplies
HL-2170w won't print with Windows 7
Windows 7 will not work with earlier Windows versions of printers
Feb 28, 2017 | Brother HL-2170W Laser Printer
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Office Equipment & Supplies
Printing error
From your start menu, go to printers and faxes area. When this opens do you see your printer listed? Is it greyed out at all or maybe listed as offline? How are you connected tot he computer? Network, USB, or parallel port connection? If you see your printer listed and it has no other duplicate listings, right click the printer and go to properties, then choose the Ports tab. Verify here that the port selected witha check mark corresponds with your connection method. Example: If you are connected through USB, your selected port should say USB. Sometimes DOT4 ports will work for USB connections too. If you see this option, you can select it and hit apply to try it out. Try to print a test page after each applied change. Also, make sure that print jobs haven't built up in your queue by double-clicking your printer icon. If there is a queue of failed print jobs, select them and cancel. This might take a moment to complete. If your printer icon is greyed out, right-click it and un-choose the work-offline option and try it.
Mar 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printing to a Canon MX310 through a print server
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Nov 11, 2007 | Canon PIXMA MX310 All-In-One Printer
211 people viewed this question
old marine
old marine
