Question about Tag Heuer Carrera Twin Time WV2116.FC6181 Wrist Watch for Men
User manual setting day and date
  • 4 Answers
Is this watch a knock-off or real.
Posted on Oct 21, 2013
U watch users guide how to set up to use
You can download PDF manuals for Uwatch smartwatches here https://smartwatchmanuals.com/uwatch-smartwatch-pdf-manuals/ Uwatch Smartwatch PDF manuals SmartWatch Manuals
Jan 31, 2017 | Watches
How do I set my watch
It all depends on the type of watch you have.
Manually, the time (and date) are set by releasing the crown wheel and turning it so that the hands move clockwise to the correct time. If you have a date function, you may have to cycle the crown wheel quite a few times to reach the correct day and date.
On digital watches, the user guide will indicate which buttons should be pressed to set the time and date. Refer to the user guide that came with your watch, go onto the manufacturer's website or go back to the store where you bought the watch and ask them to show you how to do it.
On smart watches, the time should be set automatically when the watch synchronises with your smartphone or wifi signal.
May 24, 2015 | Watches
G Shock
Hi, go to the following website G-Shock Website User Support
If you know the model number of the watch, enter it in the "Number" search field in the "Manuals" section. This should then find the correct user guide for you to download and help set the time and date. You will probably find that most models will function in the same way, so you may be able to find a similar model that sets the time and date in the same way as the watch you have.
If your not successful with that, let me know and will try and grab a manual for you that could work :-)
Cheers
Apr 29, 2013 | Watches
Can someone tell me how to set date month and day on an attention manual watch
A manual watch is set by pulling out the winder.
Those with a date have three positions:-
1 normal operation
3 fully out - used to set the time
2 half way between 1 & 3 which is used to set the date and day. In this position turn it one way to set the day and the other way to set the date.
Return the winder to position 1 after setting.
Jun 04, 2011 | Watches
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Feb 01, 2011 | Tag Heuer Formula One
I have a Timex automatic with day and date. How do I set the day and date?
I often sell vintage Timex watches which have a day and date feature. Setting the day and date feature can be a little tricky - if not frusterating if you aren't familiar with how to do it since most of the original manuals that came with these are long gone!
I'll try to explain the process - please feel free to contact me if this doesn't make sense.
1. Pull out the crown on the right hand side of the watch.
2. Advance the crown so the time advances clockwise until the day is correct.
3. Rotate the crown so the time is going counter-clockwise (the opposite direction) until the date "clicks". (the day will click first, then the date).
4. Rotate the crown so the time is going clockwise again and the date will advance.
5. Continue this back and forth action of rotation until the date is correct.
6. Push in the crown and you're done!
I'm considering making a video of this process. Please let me know if this is something you would be interested in.
Oct 30, 2010 | Timex Automatic Watch
Need manual/User Guide for an ''Athletic Works'' watch, model V403
Dave,
If you hold the reset button you will see the number 12 flashing with an H next to it this is for standard or military time. To change it press the st/stp button. To go forward press mode.Then it will ask for the year set that then press mode.Now the date change it just like the Hour and year.then day do the same.Now timeSet that the same and it should work!
Apr 26, 2009 | Watches
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Jan 09, 2008 | Citizen Eco-Drive BL5184-56L Wrist Watch
Tag Heuer Carrera Twin Time WV2116.FC6181 Wrist Watch for Men Logo
74 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
