Question about Cisco Computers & Internet
Ap5131 switch configuration - Cisco Computers & Internet
3 Suggested Answers
SOURCE: how to configure symbol 5131 through hypertrm
Hi
You can set up the AP 5131 through Hyperterminal by accessing it through COM1 to start,
19200 bits per second
8 data bits
Parity: None
Stop bits: 1
Flow Control: None.
Good Luck. :)
Posted on Jul 28, 2010
  • 1833 Answers
SOURCE: motorola AP5131 access point in
In that case you need to check the switch configurationfirst, if you try to do an advance LAN routing. You alsoneed to check LAN bridging section. The two segments will be in the same subnetand look like two Ethernet switches connected by a cable to all computers onthe subnet. Since the computers are on the same subnet, broadcasts will reachall machines, allowing DHCP clients in one segment to get their addresses froma DHCP server in a different segment. You could use a Wireless Bridge totransparently connect computer(s) in one room to computer(s) in a differentroom when you could not, or did not want to run an Ethernet cable between therooms. Contrast this with Client Mode Wireless, where the local wireless devicerunning DD-WRT connects to the remote router as a client, creating two separatesubnets. Since the computers within the different subnets cannot see each otherdirectly, this requires the enabling of NAT between the wireless and the wiredports, and setting up port forwarding for the computers behind the localwireless device. Segments connected via Client Mode Wireless cannot share aDHCP server.
Posted on Nov 01, 2011
How to upload ready configuration file into the new switch?
yes you can upload configuration file on S5300 switch flash using serial connection. Please check below link. is an upgrade guide for deploying a system software. it shows you how to upload system software to the flash, the process is the same for configuration file.
it is possible to connect a laptop to the switch? Ethernet cable, configure ip addresses, enable ftp, configure ftp user and then upload to file to the switch via ethernet?
Apr 10, 2015 | Huawei Computers & Internet
How to clean up configuration Huawei switch ? I use the switch Huawei S9306 in my network. [Y/N]:y reboot Warning: All the configuration will be saved to the configuration file for the n ext startup:,...
Maybe you should ask the manufacturer, they will give you the details configuration. And if you want to learn more about the Huawei switch configuration, please visit:
c:\docume~1\admini~1\locals~1\temp\%w@gj$acof(tydyecokvdyb.pnghttp://huaweis5700.over-blog.com
Apr 03, 2014 | Computers & Internet
Network is: 2x AT-FS713FC/SC (fiber connected with each other) behind the "remote" FS713FC i have one motorola acces point (192.168.1.48 motorola ap5131). This AP functions properly. I added a...
You got to check a few things prior to perform any troubleshooting step.
1)whenever you face a disconnection check both end FO converters and try to figure out which one lights are blinking and which are not blinking in both ends at the same time.
2) are both the converter is similar make or not? If not please specify both makes.
3)How many devices are connected on both end after the AP's(approx)? Is there any switch or hub also present within the same network?
4)whenever you face a hang/disconnection position disconnect and reconnect power from one of the FO converters and see what happens then disconnect and reconnect power in the other end and see what you get.
Please revert back with the above detail and I feel I will be able to help you out.Rather you will be able to find out where the issue lies by applying the above steps.
All the best.
Nov 14, 2011 | Allied Telesyn AT-FS713FC ST-10...
I have 2 AP5131 AP's on the same network with different IP's. I have been told they need to have separate "channels" in order for the hand held scanners to be used with them. How can I change "channels" on...
go to http:\\ip-adres-of AP5131
wait for login (java must be on your computer; otherwise click on link and install)
enter username : admin
enter password: ????
go to: Network configuraion => Wireless=>Radio configuration=>
and select a chanel.
Make sure when both AP's are to function on one network (+roaming) the channels on both should be different (f.i. choose channel 3 & 6). SSID and key;s should be the same
Make sure to save the changes on the AP.
Sep 13, 2010 | Motorola AP-5131 802.11a/b/g Wireless...
How to configure symbol 5131 through hypertrm
Hi
8 data bits
Parity: None
Stop bits: 1
Flow Control: None.
Good Luck. :)
Apr 22, 2010 | Symbol AP-5131
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
Creating MESH on AP5131
you must setup ap as repeater see manual
Dec 11, 2007 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
