Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Light doesn't work .... changed the lighting unit. perhaps a fuse? Where do I access that panel?
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: ge microwave jvm1320 light & fan no longer operate
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 20, 2008
Passanger headlight doesn't work. Brand new lightbulb no luck, fuses are good. what could be the problem
Look under the hood for a fuse panel. There should be a diagram on the lid that shows HeadLight Relays. If there is one for the left and right, try swapping them - WITH THE KEY OFF. If that changes the light that works, then either the dealer or an auto parts store should have the relay.
It's also possible the headlight harness is bad - they can overheat and melt. Verify there is no damage to the harness wired from the headlight to the fuse panel under the hood.
If you also lost the light dimmer and highbeams, you may have a short in your wiring, or the 'stalk' on the steering wheel is bad.
Td
Oct 18, 2012 | 1991 Nissan Maxima
Check engine light doesn't work
check engine light only comes on at first start and when sensors fail.. All lights in cluster run off same fuse
Aug 22, 2012 | 1995 Acura Legend
Instrument panel light is out and new headlight doesn't work
did you blow a fuse when changing the light over?
Jul 10, 2012 | 1992 Nissan Stanza
T.v is not getting any power.
Try unplugging the power for at least 10 minutes or more then plugging it back in.. If that doesn't work you may blown the transformer or fuse in the unit. If your unit doesn't have access panel for a fuse for the power supply it will need to be sent for service.
Nov 16, 2011 | Televison & Video
Left tail light only blinks with main light switch turned off. With main light switch on it doesn't work but front left turn signal works in both instances but fast with main switch on.
change the flasher unit, located behind the fuse panel on the drivers side foot kick panel , then check the bulb of the bad light, with a Meter,, you could have a bulb filament flopping around and it looks to be good , also check that the base of the bulb is clean and has good grounding
Jul 29, 2011 | 1999 Chevrolet S-10 Pickup
How do you reset the "change oil" light?
Try this procedure;
Locate the "Red" reset button towards the top of the fuse panel, in the fuse panel on the side of the driver side dash. (Open driver side door and remove the fuse panel cover to access the fuse panel and the reset button)
1. Turn the ignition key to the "On" position, but do not start the engine.
2. Press and hold down the "Reset" button until the "Change Oil" light starts flashing.
3. Then press and hold down the "Reset" button again until there is a chime or beep(s) and the "Change Oil" light should then go out.
4. Turn off the ignition, and then start the vehicle and confirm that the "Change Oil" light has been reset.
(May have to repeat the procedure to be successful)
Let me know if this procedure did not work for your vehicle as there are other procedures and depending on the type of system that is being used.
Nov 24, 2010 | 2001 Oldsmobile Alero
Have a honda odessey 2000. needs a new DRL relay; but cant find it under the dash _any ideas _
the daytime running lights control unit is behind the glove box. You must first remove the glove box to access the control unit. However, the fuses that supply power to control unit functions are accessible in several fuse boxes. the No. 3 and 8 fuses (15A) and No. 14 fuse (40A) in the engine compartment fuse box, the No. 5 fuse (7.5A) in the driver's kick panel fuse box, and the No. 6 fuse (10A) in the passenger's kick panel fuse box all supply power in some way to the DRL unit. Other inputs that can affect the DRL system include a faulty parking brake switch, faulty combination light switch, faulty headlight relays or blown bulbs, and even the brake fluid float switch.
Apr 04, 2009 | 1997 Honda Odyssey
Tail light won't work but brake light will
Check 10amp fuses #9 and #23 in the fuse block on outbord end of left side of dash panel. With driver door open you should be able to see the small access panel on end of dash.
Mar 05, 2009 | 2002 Jeep Liberty
Change oil light remains on after oil change and light over license plate does not work after bulb change
To reset the Change Oil Light: Open driver's door and open fuse access panel
Turn ignition key to on (don't crank the starter) Push reset button located in fuse panel When Change Oil Light starts to flash Press and hold reset button until it beeps and light goes off Repace panel
Jul 17, 2008 | 2003 Oldsmobile Alero
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
20 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
