Tronic power cube
Need replace mains adaptor for tronic kh 3106 power cube were to buy
2 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: Dead - no lights - checked fuse replaced main top tronic power board any ideas?
check the power cord
Posted on Jun 07, 2012
I have a konica minolta c8000 with error code c3106, what does it mean?
C-3106: Fusing unit set abnormality
1. Check the fusing unit set condition, and repair it if any abnormality.
2. Check the connection between the rear side connector of the fusing unit and the main body side connector, and repair it if any
abnormality.
3. Check the fusing unit, and repair it if any abnormality.
4. Check the connection status of PRCB connector, and repair it if any abnormality.
5. Replace PRCB.
Thread Error code 3106 Bizhub press C8000
May 31, 2015 | Konica Minolta bizhub Office Equipment &...
How long does it take a tronic 150w power inverter to be fully charged.and how long does it last after being disconnected from charging?
This device is meant to convert DC power from a car battery and similar devices into AC mains power suitable for running small appliances. It is not intended to be an energy storage device. Once plugged in, it does take a few seconds to reach peak output and will remain active a few seconds after input power is removed. This is due to the slow collapse of the magnetic field generated by the internal transformer that feeds the AC output. You'll notice this same effect in your laptop charger if it is equipped with an LED indicator light letting you know it is energized.
May 08, 2014 | Power Tronic Computers & Internet
Need to buy a charger for my Hyundai S900-charger 100-240V 50/60Hz 9v-2.5A, saw on Amazon you had thisCostMad 7 / 6 Way 1.5A 1500mA max. AC to DC Universal Universally Multi Voltage 3V / 4.5V / 6V / 7.5V /...
You can buy car accessories here,they are one of the best electronics wholesales in China. http://www.ankaka.com/Wholesale-car-accessories_c10005
Feb 18, 2013 | Televison & Video
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Mains power supply failed completely - who sell replacements?
Most stores sell multi voltage adaptors that are quite capable of running routers the only thing you reall need to check are the voltage and current requirements eg. 5 v 500 mA this is usually written on a label on the router either underneath or near where the power supply plugs in.
Any adaptor that meets or exceeds that specification will do then it is just a matter os electing the correct end (they come with a variety) to match your router.
Also check if you need centre positive or negative and set the adaptor to suit this also.
It is usually way cheaper than buying one from the manufacturer and also a lot quicker way to replace almost any pooched power supple that comes in the form of a "wall wart"
Sorry if it sound complicated but I assure you it isnt.
Aug 09, 2009 | Belkin (F5D7230-4) Router (587009)
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
