Question about Home
Err ih on culligan system, what does this mean?
Ir 6570 error code e0004 e00103
E004-0103 The IH power supply is faulty/the IH control mechanism is faulty. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
The IH current is faulty. (no current) - Check the connector for any fault in connection. - Replace the fixing heater power supply. - Replace the DC controller PCB.
This link also offers a down loadable pdf service manual.http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR6570
Apr 15, 2015 | Office Equipment & Supplies
C8 mean
irst try switching off and on the printer to reset the error.
If still there the error check the following;
Check CN983, it may be disconnected on the IH inverter.
Defective IH inverter - replace IH inverter.
Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Jul 01, 2014 | Ricoh Aficio SP C820DN Laser Printer
How do i fix a code 5 error on a culligan 100 water system?
what does c5 mean? I can't get it off the digital face and had to by pass to shut off.
Aug 21, 2013 | Culligan Sediment Water Filter
Canon ir 5570 e0004-0010
Try pressing Additional Functions then 2 and 8 simultaneously then Additional Functions again. Select Copier > Function > Clear > Err press ok. If the problem persists it will need parts. Error means that there is a problem with the IH power supply.
May 01, 2012 | Canon imageRUNNER 5570 Copier
Mark 89 continues to cycle. Unit is over 20 years old.
If it is stuck in 1 cycle (backwash for example) this generally means the piston in the sealpack is bent and has stuck in position. The sealpack has to be replaced. There is s retrofit kit that assures the piston can not be bent. These parts are available only at Culligan. Since the system is 20+ years old it may be time to consider replacing it at this point. You can get a Fleck 2510 sxt system that the Culligan was designed around.
RJ
Jul 25, 2011 | Plumbing
Our system is only running small amount of water through to the drain... system operating panel just says C5! Even after unpluging and repluging it doesn't change. Does the system need repair?
If it is running small amounts of water to the drain when it is in service position this means you have a bad seal pack and it needs to be replaced. The "sealpack" is the main piston and seals that control the hydraulics of the valve. When water runs to the drain constantly either the piston is jammed (which would show an error code) or there is a bad seal causing water to get by. I suggest calling Culligan or if you are handy you can do this yourself. You need a sealpack and refill piston. It takes about 20 minutes. The kit is available from Culligan.
RJ
Jan 30, 2011 | Culligan Sediment Water Filter
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
Culligan gold series 9'' water softener has a constant error code
It has been my experience that when you have made several attempts to correct the error codes as directed in the owners manual, you most likely have a defective controller.
You should contact Cuno and locate a service representative near you to see about getting the controller replaced.
sanray
Dec 26, 2008 | Culligan & Hand Held Filtered Showerhead
Home Logo
139 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
