Question about Brother HL5350DN Laser Printer
5350DN BROTHER IN HEAT TAKES MORE THAN 10 MINUTES, SO I HAVE 5 EQUIPMENT, CHANGING THE MAIN BOARD IS SOLVE THE PROBLEM. We updated the firmware BUT not solve the problem. THERE A WAY TO REPAIR THE MAIN BOARD? THANKS LEONARDO
    Problem Solver:
  • 15 Answers
U may need to change the heater
Posted on Oct 21, 2013
  • LEONARDO
    LEONARDO Oct 21, 2013
    and was changed around the fuser assembly thanks
    Top Expert:
  • Brother Master
  • 45,112 Answers
You may have to replace the main board.
  • LEONARDO
    yes, thanks, no way to re solve the problem without changing the main board?
Samsung un55f6300afxza sometimes won't turn on
It is a common problem with a defective main board. You may re-flow the soldering yourself by this procedure.
Re-Flow Soldering Procedure for Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Aug 31, 2017 | Samsung Televison & Video
Hi i bought a 3 years used samsung tv smart 3d 60 " and the tv turn off and turn on it self randomly sometimes it stays open 2 min , 5 min and sometimes dont even close for 5 , 6 hours straigth .. i was...
In most of the case, the problem is the main board, you may try the below procedure to fix the problem:
Aug 30, 2017 | Samsung Televison & Video
My Vizio tv has started getting distorted every few minutes. It's like the signal gets slow and is not coming in quick enough. It only lasts about 5-10 seconds
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 06, 2016 | Vizio Televison & Video
Can I fix my tv?
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ....
Sep 19, 2016 | Televison & Video
How do I rectify problem of TV shutting off
Apr 07, 2016 | Televison & Video
Canon imageclass MF 5770 download standby
Hello, your machine needs a firmware update;
this is the firmware for SCNT board assy.
E227ME MF5770 WLaa0602 MAIN
and here is the software firmware update for win Xp.
Canon MF5700 update tool
May 13, 2014 | Canon imageCLASS MF5770 All-In-One Laser...
Need to change the main board
Hi
After changing the main board, you should have to update its firmware. Without this, it won't work properly. Changing motherboard is an easy thing, but the firmware update is crucial. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Panasonic Viera TH-42PX80U Plasma TV
Beim Firmware Update stopt das System bei UPD5/5 - keine weitere Reaktion ???
the firmware update for sc-bt200 & sa-bt200 takes approx 10 mins. the box will display UPD5/5 - this process takes about 10-15 minutes, the box will switch off automatically. Leave for 30 seconds, and power on manually with your remote control - the screen will display - "firwmware update completed.".
Feb 05, 2011 | Panasonic SC-BT200 Home Theater Systems....
Error: clean unable to maintenance see user guide 50 Printer model: Brother dcp-165c Pls help me how to solve.
If the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
2. Press the STOP/EXIT and the UP ARROW key at the same time. The first 2 characters on the top row will determine the ROM version.
  • If the ROM version is OH or greater (example: OI, OJ, OK, etc), the firmware does not require updating. Go to WARRANTY AND SERVICE OPTIONS listed below.
  • If the ROM version is OA - OG (example: OB, OC, OD, etc), continue to STEP 3 to update the firmware.
3. A utility is available that will allow you to update your Brother machine with the most recent version firmware, by downloading updates over the Internet.
4. Choose your country.
5. Choose your language.
6. Choose Inkjet FAX/MFC/DCP
7. Choose your model
8. Click on "Downloads"
9. Under Notes/Information select the option - Click here to view firmware version history.
10. Close the window to continue with the firmware update.
11. To update the firmware please follow the instructions listed below:
DO NOT interrupt the process or turn off the machine once it has begun. Doing so may corrupt the memory on the machine and may require the machine be serviced in order to correct the problem.
12. Select your OS and language in Steps 1 and 2 on the website and then click on "Search".
13. In the next window, scroll down to the bottom of the page to locate "Firmware Update Tool".
14. Click on "Information & Download"
15. Scroll down to the bottom of the next page and click the "Download" button
16. Accept the license agreement.
17. A dialog box appears with options for "Run", "Save" or "Cancel". Choose "Run".
You may also download the utility for later use by choosing "Save".
18. A dialog box appears informing you that some information from the machine will be collected and stored. Click "I Accept".
19. A dialog box appears informing you what will be deleted during the firmware update. Click "Next".
20. The program will now begin to update the firmware.
Dec 07, 2010 | Brother DCP 165C Compact Color Inkjet...
After I apply the last firmware update in my Brother FAX-2820 the USB stops working. I have connected the machine in many PCs via USB and nothing. I need your help to solve the issue.
first you dont need to update the firmweare of this machine just only apply this update if you change for a new one main Pcb. If you try to update this machine you make damage your main pcb.
Oct 01, 2009 | Brother IntelliFax-2820 Laser Fax
Brother HL5350DN Laser Printer Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
