SOURCE: Region Unlock For Sony RDR GX-120 DVD Recorder
GO BACK TO THE PERSON WHO HAS REPAIRED ASK FOR FREE REPAIR AGAIN. IF HE NOT RESPONDING, TELL ME LATER I'LL HELP.
THAT TIME PLEASE MENTION FULL MODEL NO. FOR YOUR SET AND WHICH COUNTRY YOU LIVE?
SOURCE: HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
[email protected]
SOURCE: Need 3 digit code for controlling sony rdr-gx7 dvd
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
SOURCE: My Sony RDR-GX7 dvd recorder keeps giving me a
could the problem be a slipping disk?
I had this and cured it by opening up the player and levering off the round cover on the dvd drive, removing the weighted magnet, then cleaning the rubber seat.
