Question about Cell Phones
Set comes on but display white, connector opened
Set comes on but display white, connector opened cleaned , refitted but problem remains there. what part must be checked and replaced?
    Problem Solver:
  • 7 Answers
Which phone model are you using? If it's a sliding or flip phone, you need to replace either the 'flex display cable' connecting motherboard to the LCD or the LCD itself. Otherwise if its a chocolate bar kind of phone, you need to replace the LCD. Also do a physical visual check and perhaps use a bit of medicinal spirit to clean on the motherboard where the flex or LCD clips on.
Posted on Oct 21, 2013
How to replace display of ir2800
  1. Open the Right door.
  2. Open the two screws Marked as 1and 4.
  3. Open Last One screw Left side a hole in Display.
  4. Remove the connector with safety.
  5. Open the 4 Screws back side of the display.
  6. Disconnect all the Connectors.
  7. Remove all the Circuits.
  8. Remove all the Self threaded Screws.
  9. And Remove the Iron Base Plate.
  10. And Safely replace the Display with new one.
  11. Place the Touch Screen Properly.
  12. And reinstall The Iron Base Plate.
  13. Place all the Circuits.
  14. Connect all the Connectors as connect they before disassemble.
  15. Reinstall Properly the Display as Before It Place.
  16. Now on the machine and check it...boom boom..
Do not Do That:
  1. Do not use Thinner and Hard stain remover Acids.
  2. Do not clean the circuits with liquids.
  3. Connect all the Connectors at Proper port.
  4. Place the screw well fit to display and touch screen to work touch screen properly.
  5. Do not give room with Display and Touch it may not work properly.
May 14, 2016 | Canon Ir 3300 Black & White Copier
How to fix open or shorted relay circuit 3-4 shift solenoid relay condition on 2000 jeep cherokee
Check this TSB...
Set Condition: This code is set if the voltage detected on the 3-4 Shift Solenoid Control
Circuit at the PCM is difference than the expected voltage.
POSSIBLE CAUSES
FUSED B(+) FEED TO TRANS CONTROL RELAY OPEN
TRANS CONTROL RELAY
3-4 SOLENOID CONTROL CIRCUIT OPEN
3-4 SOLENOID WIRING HARNESS INTERMITTENT
SHIFT SOLENOID CONTROL CIRCUIT SHORT TO GROUND
SOLENOID AND HARNESS (SOLENOID CONTROL CKT)
SOLENOID AND HARNESS (SOLENOID PACK CONN)
TRANS RELAY OUTPUT CIRCUIT OPEN
TRANS RELAY OUTPUT CIRCUIT SHORTED TO GROUND
PCM (3-4 SOL CONTROL CKT)
PCM (CODE SET)
POWERTRAIN CONTROL MODULE
TEST ACTION APPLICABILITY
1 Key On.
With the DRB, read trouble codes.
Is the Trans 12 volt Supply Relay Control Circuit code set?
All
Yes - Refer to symptom P-1765 TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT in the TRANSMISSION category.
No - Go To 2
2 Key On.
Is the DTC Specific Good Trip displayed and equal to zero?
All
Yes - Go To 3
No - Go To 17
555 TRANSMISSION
3 The code is present at this time.
Key On.
Check and record Freeze Frame data to determine the conditions when the code was set before disconnecting the PCM Connectors.
Note: Freeze Frame data will be erased.
Road test Vehicle. Attain Vehicle speed of at least 50 MPH.
Push OD Switch 4 times such that Vehicle attempts to shift from 3rd to 4th and back.
Did the Vehicle shift between 3rd and 4th?
All
Yes - Go To 17
No - Go To 4
4 Key Off.
Disconnect the Trans Solenoid Pack Connector.
Note: Check connectors - Clean/repair as necessary.
Turn Key On.
With the DRB, actuate Trans Control Relay.
Using a Voltmeter, measure the voltage at the Trans Relay Output Circuit.
Does the voltage fluctuate from 0.0 volt to over 10.0 volts?
All
Yes - Go To 5
No - Go To 13
5 Key Off.
Disconnect the Powertrain Control Module White Connector.
Key On.
Using a voltmeter, measure the voltage at the 3-4 Shift Solenoid Control Circuit.
Is the voltage above 10.0 volts?
All
Yes - Go To 6
No - Go To 7
6 Key Off.
Repair 3-4 Solenoid Control Circuit shorted to voltage.
Reconnect all disconnected Connectors.
Push OD Switch 4 times such that Vehicle attempts to shift from 4th to 3rd and back.
All
Yes - Test Complete.
Perform Powertrain Verification Test VER-5A.
No - Replace the PCM.Perform Powertrain Verification Test VER-5A.
7 Key Off.
Using a Ohmmeter, measure the resistance between the 3-4 Shift Solenoid Control
Circuit at the PCM Connector and Ground (B-).
Is the resistance below 5.0 ohms?
All
Yes - Go To 8
No - Go To 9
556 TRANSMISSION
8 Key Off.
Using an Ohmmeter, measure the resistance between the 3-4 Shift Solenoid Control
Circuit at the PCM Connector and Ground.
All
Yes - Repair the 3-4 Shift Solenoid Control Circuit shorted to ground.
No - Replace the Solenoid and Harness Assembly.
9 Key Off.
Remove the Trans Control Relay.
Using an Ohmmeter measure between the Trans Control Relay Output Circuit at the
Relay and the 3-4 Solenoid Control Circuit at the PCM Connector.
Is the resistance above 40.0 ohms?
All
Yes - Go To 10
No - Go To 12
10 Key Off.
Using an Ohmmeter, measure the 3-4 Solenoid Control Circuit from the PCM
Connector to the Solenoid Connector.
All
Yes - Go To 11
No - Repair the open 3-4 Solenoid Control Circuit.
11 If there are no potential causes remaining.
View repair options.
All
Repair
12 Key Off.
Using a Ohmmeter measure between the Trans Control Relay Output Circuit at the
Is the resistance between 26.0 and 40.0 ohms?
All
Yes - Replace the PCM.
557 TRANSMISSION
13 Key Off.
Key On.
Using a Voltmeter, measure the Fused B(+) Circuit in the Relay Connector.
Is voltage above 10.0 volts?
All
Yes - Go To 14
No - Repair the open Fused B(+) Feed to the Trans Control Relay.
14 Key Off.
Using a Ohmmeter, measure the Trans Control Relay Output Circuit from the Relay
Is the resistance above 5.0 ohms?
All
Yes - Repair the open Trans Relay Output Circuit.
No - Go To 15
15 Key Off.
Using a Ohmmeter, measure between the Trans Control Relay Output Circuit and Ground.
All
Yes - Repair the Trans Relay Output Circuit shorted to ground.
No - Go To 16
16 If there are no potential causes remaining.
All
Repair
Replace the Trans Control Relay.
17 Key On.
Check and record freeze frame data to determine the conditions when the code was set.
Erase the DTC.
Warning: This will erase the Freeze Frame data.
Attempt duplication of Freeze Frame Data to help reset the code.
Key Off.
Using the Schematic as a guide, inspect the Wiring and Connectors.
Were any problems found?
All
Yes Repair as necessary.
No Go To 18
558 TRANSMISSION
18 Key On.
Note: Actuate the 3-4 Solenoid or the test can be done with the Engine running.
Wiggle the Wiring Harness from the Solenoid to the PCM.
Note: You are attempting to set the code.
With the DRB, read DTC's.
Does the 3-4 Solenoid Control Circuit Trouble Code appear?
All
Yes - Repair as necessary.
No - Test Complete.
559
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 02, 2011 | 2000 Jeep Grand Cherokee
My nokia 6300 just changed. the dispay writing is now upside down and in reverse. what is the prob and how do i get it back. i have tried restoring factory settings but no success.
You mean that it is showing you a Mirror look if like that then please refit the display. to refit your Display use the T6 screw driver to open your mobile there are 6 screw's first 2 screw's are below or back cover then other 4 screw's in front side of mobile remove the front penal then there you will get thous 4 screw's remove all 4 screw's take out the mother board after doing this remove the display shield it is metal shield remove the display with its display connector that is placed behind the Bord agen there you'll find the metal cover remove that then unplug the display with display connector and refit that on same place then refit all the things which you have removed then start then mobile it will get solved is not then you should it ones agen if your not a mobile technician then please dont try to do this.
If your not a Mobile Technician the Please Visit your nearest Nokia Service Center (Nokia Care) or Visit any Mobile Repair Center they will Doit in proper method.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jul 04, 2011 | Nokia 6300 Cellular Phone
Error code E-1F5- came up on self cleaning oven before cycle was done what does this mean door wont open
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 20, 2011 | Whirlpool 30" Self-Cleaning Slide-In Gas...
Time left display flashes LE.
It is a locked motor error. One of the following is causing the problem but you may need the help of a qualified appliance technician:
  1. The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of the stator assembly. Connect them properly.
  2. The electrical contacts between the connectors (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main board assembly is bad or unstable. Clean the connectors and connect them properly.
  3. The motor harness between the stator assembly and main board assembly is cut or open. Reconnect or rewire.
  4. Motor winding is defective. Check the resistance between the terminals of the stator. Resistance should be between 5 to 10 ohms, else replace the stator.
  5. The hall sensor is out of order/defective. It is located at the stator assembly. If the hall sensor is out of order, it cannot detect magnetic field and the main board sees it as the rotor is locked then displaying the error code. Replace it if no evidence of defect is found above.
Nov 10, 2009 | Washing Machines
Oven wont come on -I get E1 F5 on display.
A. Disconnect power from unit.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
Jul 04, 2009 | Whirlpool Ovens
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fujifinepix F30
Maybe it the connector inside is loose, you might try to open the case (a 5 euro triblade / triwing screwdriver is needed) and see if any of the connectors is loose, before sending it for a 160 euro repair.
Nov 21, 2007 | Fuji FinePix F30 Digital Camera
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
