Question about Lands Phones
Reset panasonic cordless phone
Base unit beeps every 10 minutes
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
What model Panasonic phone?
Posted on Oct 21, 2013
4 Suggested Answers
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: Range extender for cordless phone
Ours behave similarly. The solution is to position the "base" (one connected to the phone lkine physically) in the center of the home so that the limited range can reach the remote phones at the periphery.
These phones operate at 1.9GHz. At that microwave frequency radio signals do not penetrate walls and floors very well. 2.4 GHz phones suffer increased "path loss" and are no better. The solution for any of these microwave phones is more transmitter power, which is illegal.
900 mHz phones actually work better because at 900 MHz nature offers less signal path loss", but try to find them in stores! For the same transmitter power level a 900MHz phones will have noticeably greater range.
The 1.9GHz D.E.C.T. phones also operate differently from other types of cordless phones and I believe that also contributes to dropped calls and the phone's inability to ring when a call arrives. At the fringe of its range you can see how it struggles to establish a link. Once established it will work well and then simply drop the call when you least expect. I am not a fan of the DECT phones, but they do not interfere with 2.4 GHz wireless routers, etc.
Posted on Sep 13, 2009
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
Posted on Sep 29, 2009
My KX-TG2322 takes neither incoming messages nor outgoing ones` it says 'Memory Full', although no message is there.
Erasing all messages
All recorded messages, except the greeting
message, can be erased at one time.
1-Press [ERASE] while the base unit is not
being used.
• "To erase all messages, press ERASE again" is
heard.
2-Within 10 seconds, press [ERASE] again.
• The unit beeps, then announces "No
messages".
• The base unit display shows "0".
Mar 08, 2015 | Panasonic KX-TG2322B - 2.4ghz Digital...
I purchased replacement handsets for my older panasonic cordless phone and would like to know how to reprogram them. My base unit has an answering machine but not a locater button. Thanks, Ann-Marie...
Follow these steps to register new handset.
1. On your Handset: Press Menu -> [0] [0] (menu then zero zero)
2. On your Base:
- Press and hold [Locator/Intercom] until the CHARGE indicator flashes.
The following must be completed within a minute.
3. On your Handset:
- Press [OK], then wait until the handset beeps.
That's it.
Hope this helps.
May 06, 2011 | Panasonic KX-TG5632 Phone
How can i set up speed dial?
Registration Register the handset to a KX-TG6700/KXTG6702 base unit. 1 Base unit: Press and hold {INTERCOM} until the IN USE indicator flashes. L After the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 2 Handset: Press {OK}, then wait until a beep sounds.
http://adcombhs.com/shopsite_sc/store/html/Panasonic_KXTGA670.pdf
Mar 07, 2011 | Panasonic KX-TGA101S Cordless Handset
My answering machine message is out dated and needs to be changed how do you do it?
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes). If you do not
record a greeting message, a
prerecorded greeting message is used.
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 To stop recording, press {STOP}.
Feb 11, 2011 | Panasonic KX-TG6021M Cordless Phone
Panasonic KX TG9331 no link to base Even standing next to the base, I cannot answer the call. Sometimes repeated pressing of the talk button lets me talk. Also, switching to speaker phone sometimes drops...
Sounds like a defective handset or base unit. Unplug the base unit from power and the telephone jack. Leave unplugged for 1 minute, this sometimes helps the phone to reset from a problem. Unplug the battery from the handset and plug back in after a minute also to help reset. Place your handset in the base unit for about 1 minute to allow the handset to link up with the base unit. If this doesn't work you may have a defective phone. Contact Panasonic support for further information if this does not work.
Aug 29, 2009 | Panasonic KX-TG9331T Cordless Phone
My panasonic kxtg9331t beeps every few minutes or so from the home base (message unit). Does anyone know why? Each of the 3 extension unit handsets are fully charged. Thanks.
Sounds like you may have a "new message" alert indicator. Have you checked that? Go thru the menu on one of the hand sets and find answering machine set up and turn off message alert.
May 15, 2009 | Panasonic KX-TG1033S Cordless Phone
Portable hand set will not hold charge longer than 10 minutes.
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps are worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Mar 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
Digtal answering machine not working.
I don't know yet if this is a resolution, but I'm going to try this tonight. Unplug all bases and remove all batteries from all handsets -- leave this overnight.
Here's the history of my problem. I rec'd this phone for my birthday. 3 weeks in, power went off in my building and answering machine part stopped working. I took it back to the store, and they gave me a new one. 4 weeks in, another power outage and I have the same problem. I called Panasonic, and they told me to unplug all bases and remove the batteries in the handsets for 'a few minutes' to reset the units. I waiting 10 minutes, and replaced all batteries and plugged in all the bases again. No luck, answering machine still did not work. I noticed, however that the phone did not reset as I still had all my phone numbers and caller id history.
I called my brother who is an electrician, and he advised me that the base has a 'capacitor(sp?)' and it will probably take a few hours for it to 'drain' so the phone will reset itself. His suggestion is to unplug all the bases, remove all the batteries and leave everything OVERNIGHT. By that time, the power store in the base should hopefully be wiped out and the phone should reset like new. I will try this tonight and let you know if this works.
Jan 31, 2009 | Panasonic KX-TG1033S Cordless Phone
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Lands Phones Logo
64 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
