Question about HP C4680 All-In-One Inkjet Printer
Print cartridge problem hp c4680 - HP C4680 All-In-One Inkjet Printer
    Scholar:
    New Friend:
  • 43 Answers
1. remove all the ink cartridges from the printer and then clean the copper contacts with a lint free cloth put it back in and check if that helps..
2. then unplug the power chord from the back of the printer without turning off the printer and then press and hold the power button for 30 sec. then release the button and then plug in the power chord at the back of the printer and check if that helps..
3. try changing the ink cartridges as it might be an issue with the ink cartridges... however if you have already done that then most probably its an issue with the printer hardware.. you should call HP and ask for replacement...
Posted on Oct 21, 2013
michaelshaun
  • 126 Answers
SOURCE: I have a new HP C4680 printer. When I print from
try printing a test page from the printer and if it works fine you need a software(HP smart web printing )
and you will get the software in the following website :
www.hp.com/go/smartwebprinting and there would be instructions given in the same page download and install the printer software and try printing from the internet using teh software and it shoul print perfect though it is complicated but this has been the best resolution for printing online
hope you liked the software and everything works fine
if you still have questions get back to us and we will surely help you
thanks
regards
Hamid
Posted on Feb 20, 2010
  • 313 Answers
SOURCE: After refilling original HP60XL I get an incompatible ink cartrid
use GENUINE cartrigdges
Posted on Apr 13, 2010
  • 739 Answers
SOURCE: HP C4680 Goes Offline
Hi
Just a thought, did you use the HP CD that came in the box?
Go to Apple's website and look under the support - downloads section. You'll find a mega-sized download of up-to-date HP drivers. Download it and install it.
Then open the print and Fax setting in system preferences and remove the existing HP printer, You should then have no printers listed in the printer box.
make sure the printer is connected to the macbook and switched on and then use the Plus symbol to add a new printer. In less than a moment your printer name should appear in the empty space. Select it and wait. You should then get a thing saying 'Print Using...." It should fill in automatically with info about the driver being used.
Do what ever it asks and then close the window and see if you can print without the earlier problems.
Posted on May 04, 2010
  • 524 Answers
SOURCE: C4680 keeps jamming when I print on photo paper
hi...
please check weather the paper you inserted are with in this range
A4, legal, envelopes: 75 to 90 g/m²; cards: up to 200 g/m²; 10 x 15 cm photo: up to 280 g/m²
if the paper you inserted exceeds this weight the problem may occur
please vote me if my answer was usefull to you
Posted on Jul 14, 2010
SOURCE: Carriage jam on HP C4680
Have you checked to see if you have a paper jam in the back entrance of your printer. Make sure there are no pecies of paper jamed on the roller.
Posted on Jan 21, 2011
Hp photosmart c4680
The HP C4680 is a powerful all-in-one printer that combines an easy interface and connection process with powerful printing capability.
With a small time investment and minimal effort, even the least tech-savvy home user among us can have their HP C4680 up and running in no time, and take full advantage of all of its printing power.
Connect the AC adapter from the AC terminal on the upper right-hand side of the back panel of the printer to an electrical outlet or surge protector.
Power on the printer using the power button on the front panel of the printer and specify language and country preferences using the prompt on the main display of the printer.
Remove the pink tape from the print heads on the provided ink cartridges.
The tape should come off easily with gentle pressure.
Install the cartridges by opening the main door on the front of the printer and placing the cartridges into the cartridge cradles.
The HP logo should be facing up. Push the cartridge into the cradle until it clicks into place.
Attach the USB cable from the printer's USB port to a USB port on your computer and power on the printer.
Install the setup CD that came with the printer into your computer's CD-ROM drive and follow the steps for installing the printer software on your computer.
Your HP C4680 is now set up and ready to use.
HP Printer Driver Packages
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
Aug 09, 2013 | Computers & Internet
C4680 print cartridge problem
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 06, 2011 | HP C4680 All-In-One Inkjet Printer
I have an HP C4680..After a paperjam I am unable to print black and white. Copy comes out a very light green, almost unreadalbe...any suggenstions
Sometimes the Paperjam can cause the print heads to mis-align. Pull out the cartridges, turn the printer off. wait 2 mins or so, turn the printer back on, replace the cartridges and try again. Also ink can build up on the print heads, causing print quality issues. See this link to clear it up. http://www.fixya.com/support/r3986425-unblock_print_heads
Regards GM
Apr 05, 2011 | HP Photosmart C6380 All-In-One InkJet...
Carriage jam on HP C4680 printer after putting in new ink cartridges
Jan 20, 2011 | HP C4680 All-In-One Inkjet Printer
I have an HP photosmart C4680. It keeps turning on and off by itself. I checked the plugs, they are not loose.
http://h30434.www3.hp.com/t5/Other-Printing-Questions/HP-Photosmart-C4680-Problem/m-p/622051#M35537
Jan 10, 2011 | HP Office Equipment & Supplies
hi...
Jul 14, 2010 | HP C4680 All-In-One Inkjet Printer
thanks
regards
Hamid
Feb 18, 2010 | HP C4680 All-In-One Inkjet Printer
HP C4680 All-In-One Inkjet Printer Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
