Question about Refrigerators
I have a Deft Fridge freezer model c380 - everything worked well until we moved from Westville to Scottburgh in April 2013 - since then I have replaced the interior light about six times. I have used Eurolux, Osram, Philips and one other brand that I can't think of at present. Can you give any explanation or solution to this problem? ehbell@polka.co.za
  • 31 Answers
Buy a higher voltage light bulb if you can with same wattage and base size. It wont be as bright but should last longer
Posted on Nov 07, 2013
TJBENGR
  • 121 Answers
SOURCE: Whirlpool fridge freezer ART 462/R.
Is the 8 degrees centigrade? If yes check the freezer fan or for frost at back of freezer...and give me a holler.
Posted on Apr 21, 2008
  • 833 Answers
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Posted on Nov 12, 2008
  • 2920 Answers
SOURCE: fridge quit cooling after i moved it
did you tilt it when you moved it and then when u got it in place plug it in? if so youve got compressor problems, anytime you tilt a fridge you have to let it set for several hours to allow the oil to get back to the compressor or you ruin the compressor
Posted on Jan 01, 2009
  • 85 Answers
SOURCE: Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Posted on Jun 17, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Aug 19, 2009
Testimonial: "I'm going to check this out right now. Thank youy for your input."
Our sharp fridge/freezer model SJ-45F-WH ISNT GETTING COLD IN THE FRIDGE. THE FREEZER IS WORKING PERFECTLY.WE HAVE TURNED IT OFF FOR A FEW HOURS AND TURNED IT ON AGAIN. THAT WORKED LAST TIME.Not now.
If your freezer is full of food move everything about an inch away from the back wall. This should let the air flow better the fridge gets its cold air from the freezer. So you have to make sure your not blocking the vents.
Nov 03, 2016 | Sharp Refrigerators
May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
Jul 27, 2008 | Maytag Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Sporatic operation,changed thermister and defrost bimetal switch.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 11, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have defy fridge/freezer combo c380, freezer gets cold at bottom but fridge above does not want to, what can be the problem?
Defrost cycle has problems. Could be defrost timer, heat element, or defrost stat. temporary solution, if you can see ice accumulated inside the fridge on the back wall, desconnect or turn it off, until this ice it's gone, can be use for couple days, until service could be done on it.
Dec 23, 2009 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Fridge not cold as should be
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
May 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
MX does not work anymore
Make sure the Deft control is set to OFF. Push the volume control until you see Deft on the screen and turn the knob until it says off on the screen.
Aug 05, 2008 | Alpine CDA-9827 CD Player
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
