Question about Kohler Archer Clearflo 1-1/2in Bath Drain with Slotted Overflow Cover - K-7
How to snake kohler archer - Kohler Archer Clearflo 1-1/2in Bath Drain with Slotted Overflow Cover - K-7
Which is a good quality brand and model sink for a bathroom?
Kohler k-2355-0 Archer Undercounter Bathroom Sink
Overview
Kohler has become a warm trend in light commercial and residential bathroom and restroom design in recent years. The Archer undercounter toilet features the transitional aesthetic of the Archer Suite, blending subtle design elements create in craftsman furniture's chamfering methods and the intricate surfaces of jewelry.
This mixture of chamfered edges and curved bases create an endless appeal that suits a collection of design ideas. If you are looking for top recommended Archer Undercounter Bathroom Sink, then KOHLER K-2355-0 Archer Undercounter Bathroom Sink is my suggestion.
The KOHLER K-2355-0 Archer Bathroom Sink, completed with a lot of competences which makes it great product. This sink provides clamp assembly classic rectangular basin which is 19-7/8?L x 15-5/16?W x 7-1/2?H.
Specifications
  • Installation Type: Undermount
  • Basin Depth: 3.75"
  • Basin Width: 13"
  • Basin Length: 17-5/8"
  • Material: China
  • Number of Holes: 0
  • Shape: Rectangle
  • Style: Contemporary/Modern
  • Texture: Polished
  • Drain Outlet Connection: 1-3/4"
Mar 17, 2018 | Home
Why is tank wobbly upon install on kohler archer toilet?
The tank mounting bolts could be loose or the tank could be incorrectly seated. Be careful not to tighten the bolts too much and crack the tank.
Jul 20, 2014 | KOHLER Archer Toilet Tank, White
Leaking on the floor
I would start at the tube coming off of the fill valve. it often works its way out of the center stand pipe inside the tank. if not i would check the tank to bowl bolts and the gasket in between the tank to bowl.
Apr 29, 2012 | KOHLER Archer Toilet Tank, White
Water leaking from around the base of the flush valve. I purchased a new gasket but cannot remove the jamb nut. The wrench seems to deform the plastic and the whole assembly turns rather than the nut. Any...
Use a gripping pair of pliers but still be gentle hold the assembly and then try to turn it make sure you are not turning it the wrong way in plumbing somethings turn the opposite direction than normal when tighting and loosening
Sep 14, 2011 | KOHLER Archer Toilet Tank, White
The plumber can not figure out how to snake out the tub. He says that he can't take of the metal piece over the air gap
Drill out the screw, remove the strainer and then retap to the next size larger stainless or brass screw.
Dec 20, 2009 | Kohler Archer 5ft Whirlpool with Comfort...
Archer tank always running. don't know how to fix
If there is always water running into the toilet bowl, replace the tank ball. That's the stopper at the bottom. If you can lift the float and stop the water, either replace the sealing diaphram at the top of the ballcock (float valve) or replace the whole unit. Some are not repairabe.
Oct 31, 2009 | Kohler Archer Toilet Tank, Almond
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
New bathtub chipped
You should ask a lawyer for advice on who should fix it, but there are kits available to patch chips like those. You apply it as a liquid and then wet sand it. They are fairly easy to apply, and inexpensive.
Dec 22, 2008 | Kohler Archer 5ft Whirlpool with Comfort...
Kohler Archer Clearflo 1-1/2in Bath Drain with Slotted Overflow Cover - K-7 Logo
75 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
