Question about Sharp Office Equipment & Supplies
On a MX-5111N, im getting a message saying to replace the waste toner container. I emptied the waste toner container, but the message was still there. so I replaced it with a new one, but still received the same message. I've reset the machine multiple times and the message would go away, but would return after a few copy jobs
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Waste toner sensor is blocked ,just check it on right lower side.
Posted on Jan 08, 2014
muleskinner2
  • 270 Answers
SOURCE: WASTE TONER CONTAINER
The Counter for the Waste Toner has to be reset. You go into service mode by selecting Additional Function, then depress the 2 & 8 at the same time then the Additional function key once again. You should see a screen that says copier, feeder, etc. Touch " Copier " and then you should see a new menu across the top of the screen. Far right is " Counter ". Select it and then go to " MISC ", you should see Web, Waste toner, etc. Select Waste toner and select the " C ( clear ) " key and the counter should reset to all zero's.. Select the reset key a couple of times to get out of service mode. You may want to see what's all in service mode to get an idea of what's there. When replaceing time change items most likely there will be a counter to reset in the same way. Good Luck.
Posted on Oct 17, 2008
  • 168 Answers
SOURCE: Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Posted on Jan 03, 2009
  • 9 Answers
SOURCE: Replace used toner message still on
You have to clean the small clear tape tab on the side of the bottle. The "eye" sees whether or not the bottle is full.
You can remove it, clean it and replace it. Use caution with it. I've actual made new ones using clear packing tap on top of a small piece of clear plating that I cut out to fit on there.
Good luck. Be sure to rate this if it helps.
Posted on Apr 06, 2009
Cogz
  • 1326 Answers
SOURCE: a message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Posted on Apr 15, 2009
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
Message: drum full of waste toner. replace drum cart. Does this mean it's time to replace the drum cartridge or do we just empty the overflow? Please e-mail april@happyvalleycc.org
Empty the container that holds the "waste" toner.
You may have to use the controls on the printer to say that you have emptied the container, because the printer is "estimating" (not actually "measuring") how full the container has become, based on the number of pages that have been printed.
May 29, 2010 | Dell 3010cn Laser Printer
Replace waste toner container message
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
144 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
