Question about Vehicle Parts & Accessories
How do you calibrate the remote starter - Vehicle Parts & Accessories
    Master:
  • Vehicle Part... Master
  • 377 Answers
Have it re-programmed
Posted on Oct 22, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
What is calibration developer for bizhub 950.thanks sir
no such thing. are asking for the procedure to calibrate after replacing developer????
Dec 05, 2016 | Konica Minolta 950-281 Genuine Konica...
My remote start quit working all of a sudden. The lights and everything comes on like its supposed to but it doesn't start. The remote still locks and unlocks
My Remote Car Starter Stopped Working! - DON'T PANIC!
www.mobileedgeonline.com > Remote Car Starters
This time of the year rarely a week goes by that we don't get a call from someone stating that their remote car starter stopped working. Nearly every call is the ...
So Your Remote Starter Stopped Working.... Just Relax!
www.wssdriveeasy.com/remote-starter-stopped-working/
Sep 29, 2013 - You press the button on a cold Winter day to find that your remote starter stopped working! Take a deep breath. It is probably something very ...
My remote starter is not working, how do I fix this? - Compustar
https://support.compustar.com/.../202533874-My-remote-starter-is-not-w...
When your vehicle's remote start stops functioning the solution can change depending on each situation. The Compustar remote will not...
Remote Starter Won't Start - YouTube
? 1:02
https://www.youtube.com/watch?v=EuHu2VFx0ks
Nov 4, 2012 - Uploaded by daniluchison
Remote controls sends signal to Remote Starter but after a few 'clicks' it won't start the ... 04-08 Pontiac ...
remote start problems - YouTube
Jan 14, 2016 | Cars & Trucks
There is no sound when I login remotely
this model does not have remote connection, check batteries
Sep 01, 2015 | Extech 407766 Sound Level Calibrator,...
My harmony touchscreen remote is working intermittently. sometimes taking out the batter works but it is not working now.
try recalibrating the lcd. to do this, please follow the steps below:
One can incorrectly calibrate the remote by pressing areas on LCD other than the ones marked during the calibration process.
Solution
To re-calibrate a remote which has been incorrectly calibrated, please follow these steps:
  1. Put the remote in safe mode.
    1. Remove the battery
    2. Hold down the System Off button on the remote while inserting the battery back into the remote
    3. Continue to hold the System Off button until the remotes LCD has lit up and reads Safe Mode
    4. Let go of the power button
  2. Reboot the Remote
    1. Remove the battery once more
    2. Re-insert the battery
  3. Follow the calibration wizard on the Remote to re-calibrate it by pressing on the areas indicated.
Jan 12, 2010 | Logitech Harmony 1000 LCD Touchscreen...
My Harmony 1000i remote isn't responding to touch or won't turn
Hi. Try the following steps to get this fixed.
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
Now, put the remote back into safe mode, then take the battery out and re-insert it. The calibration screen should come up. Touch the red dots to calibrate the screen.
Hope that helps!
-D
Nov 16, 2009 | Logitech Harmony® 1000i Remote Control
Can't Kill the zombies
I have the same problem. The crosshair worked for a couple of hours and all the sudden the player 1's crosshair does not show up and cannot aim, while player 2 remote was perfectly fine.
I have tried to calibrate it again. Doesn't work.
I have tried to disconnect the remote and reconnect it. Doesn't work.
I have tried to synk the remote and the console, doesn't work.
I have tried to change to another new remote and make sure the battery is full. Doesn't work.
I have tried to reset software, turn off and on the console. Doesn't work.
Finally, I figured it might be the Calibration I did at the beginning mess up the system (why the vedio on youtube with a SEGA guy told us to calibrate???!). So I tried to delete the memory of my HOTD file and set up a new account (put in the disk and select the game again after deleting the original file) and it works!! EVERYTHING WENT BACK TO NORMAL.
Bad thing about this method is that we lost all of our paly history (credit, life, scores) by doing this and have to start from scratch again.
Remember! DO NOT CALIBRATE YOUR REMOTE!!!!!
Dec 20, 2008 | Sega House of the Dead 2 & 3 Return for...
Touch Screen and Remote Problem
My remote stop working. I replaced the 2 AA batties by still does not work
Oct 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
DVP-NS300
I'm guessing that you suspect the laser is dirty because it's having a hard time reading (or gives you the C;13;00 error).... It's not. The motor that spins the disc has defective brushes (a VERRRRRYYYY common Sony problem). They only sell the motor as part of the laser assembly for about $80. :( sorry!
Sep 11, 2007 | Sony DVP-NS300 DVD Player
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
