Question about kawasaki Krb750b Backpack Leaf Blower
While running blower starts dying down in power going up and bown and cuts off
  • 2,113 Answers
I wonder if it is starting to seize. Have you been using cheap ethanol gas. Or have you done research online for gas stations that sell real gas? If you don't use real gas on a 2 stroke engine it will over heat and eventually burn the valve and cause distortion all over. It will eventually seize.
http://pure-gas.org/
Posted on Oct 21, 2013
Homelite blower pull cord frozen how do i troubleshoot it
go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
May 12, 2014 | Homelite Garden
1993 Chevy truck surging then dying
i take it you mean the revs keep going up and down
this effect is called hunting
this means you have to much air getting through to your engine
solution: tighten down your carburetor
you may have to replace the inlet manifold gasket seal
then adjust the throttle as required
Mar 14, 2014 | Tecumseh Snowblower Snow Blower Starter...
My husgvarna staggers after a while of cutting then dies whats the problem
i am going to guess that it won't restart immediately after it dies either. It sounds to me like an ignition module going bad. it gets hot then cuts off the spark, once it cools down it starts and runs again until it gets hot again
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 27, 2013 | Garden
Leaf blower works for a few minutes real good then dies
Could be a fuel tank breather issue, when it starts to die just slacken off the fuel cap to allow some air into the tank, if it picks up again then it is a breather issue.
Mar 14, 2012 | Homelite Garden
Will start, but dies soon after. There is no choke on this mower. Engine speeds up and slows down before dying.
The float in the bowl and needle needs to be changed or cleaned real good. The float is opening up the needle enough to get it running but not floating in the fuel bowl to keep the right amount going to carb.
May 08, 2010 | Toro Lawn Mower With Toro Power Tools
It runs good thin it bogs bown and flutters
what fuel mix are ya running you should be running 40.1 or 50.1 somethings causing the engine to get to hot to run it should run cool to keep running
Nov 02, 2009 | Poulan Featherlite Gas Blower, with Low...
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Apr 08, 2009 | Amana PTH153B50AJ Heat Pump Air...
did you check the volts? and the amps.
Apr 08, 2009 | Amana PTH123B25AJ Heat Pump Air...
2000 grand prix 3.8L code comes up as evap. system what could it be?
I had this problem and I replaced the mass air flow sensor and it runs great, was told by my mechanic it is a hard problem to diagnose. I just unplugged the maf sensor and the car ran better so i replaced it.
Oct 08, 2008 | 2000 Pontiac Grand Prix
kawasaki Krb750b Backpack Leaf Blower Logo
127 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
