My cannon ir 3300 xerox printer scanner light blinking to 10 mins pleas tell me the problem
SOURCE: ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Posted on Feb 10, 2009
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
  • 525 Answers
SOURCE: My xerox machine cannon IR
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Posted on Jan 20, 2011
SOURCE: I HAVE A CANON IR
my xerox problem E000064-0000
Posted on Mar 15, 2011
abdulkarimap
  • 149 Answers
SOURCE: default Id & Password ir 3300 canon
I suggest you read the manual book canon IR3300.
Manual book, you can download here
Canon imageRUNNER 2200_2800_3300 Reference Guide
For additional materials, the solution to the problem IR3300 ID & password, you can read here
I hope this information helps
Posted on Nov 18, 2011
Darkness in botom part of pare in xerox copy only this is not appear in print by computer drum is all ready new
Then there is something wrong with the scanner. Have you tried cleaning the platen glass?
Feb 21, 2015 | Canon Ir 3300 Black & White Copier
CODE ERROR 100 SHOVING IN I R 3300 CANNON XEROX
You may need to replace the laser, it may have failed, this is from the service manual
E100
0001 The BD signal is not detected 10 times or more within 10 msec in 5 msec
after the generation of the laser drive signal.
0002 While the laser is ON, the BD signal cycle is outside a specific range 20
times or more continuously.
0003 While the laser is ON, the horizontal sync signal cycle is outside a specific
range 20 times or more.
Main cause The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The
laser scanner unit is faulty. The DC controller PCB is faulty.
Action
1. BD PCB
Try replacing the BD PCB. Is the problem corrected?
YES: End.
2. Laser scanner unit, DC controller PCB
Try replacing the laser scanner unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
anual.
Aug 30, 2014 | Canon IR 3300 Digital Copier
E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
Feb 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
Canon ir 3300 xerox machine display board not working
Feb 13, 2009 | Canon Office Equipment & Supplies
PRINTER
You have to have the telugu fonts installed in the machine otherwise, the other work around, you have to make the Canon print as an image and not as a text.
Apr 20, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
k24674
jasbo
jasbo
