How do i fix sc 793 on my af2027 - Office Equipment & Supplies
My lexus rx 330 Vsc and check light is ON. Scan shows codes C1224, 1201 and PO 793. How do I fix it
Fix the P0793 code. Intermediate shaft speed sensor. The others will go away, depending on the year of your car. Any transmission codes and some engine codes will shut down ABS and VSC systems.
May 14, 2016 | Lexus Cars & Trucks
How can I clean the drum? and how to keep it properly? in ricoh 3035 copier. there is already a cleaning blade. many thaaaaaaaaaanks
I think the best thing you can do is to buy a drum cleaning blade.
Here is a relevant link.
http://www.aliexpress.com/item/Free-shipping-RIC-H-AF1015-Drum-cleaning-blade-2ps-B039-2289-AF1018-MP1600-MP2000-AF1027-AF2027/953748540.html?aff_platform=aaf&sk=vi2iqa6b%3AQnq3BybMJ&cpt=1430853166033&af=5483&cv=41107&cn=1581789462&dp=v4_5483_41107_1581789462_&dl_target_url=http%3A%2F%2Fwww.aliexpress.com%2Fitem%2FFree-shipping-RIC-H-AF1015-Drum-cleaning-blade-2ps-B039-2289-AF1018-MP1600-MP2000-AF1027-AF2027%2F953748540.html&aff_trace_key=37385061499854849
May 05, 2015 | Ricoh Office Equipment & Supplies
Sc 395 ricoh aficio 3045
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Jul 05, 2012 | Ricoh Office Equipment & Supplies
Left cartridge inncorrect
It would be better to fix it with pitney bowes ink cartridge 793-5. You should try to replace yours with this one for easy fixing.
May 26, 2012 | Lexmark X5495 Printer
Ricoh aficio 1027 sc-793
revisar el modulo inversor
Mar 13, 2012 | Office Equipment & Supplies
I need jamo avr-793 service manual
try visiting jamo website and see if the info you need is on there. hope this helps
Feb 16, 2012 | Jamo AVR-793
Jamo avr 793 service manual
I need this manual.
Feb 06, 2012 | Jamo AVR-793
Ricoh af2027 please wait with a wrench no code
Hi that normaly indicates the there is something wrong with the HDD. open the back of the machine and unplug the HDD. Swith the machine on. If it turns on the HDD is faulty. The machine will work without the HDD but you will not be able to use the doc server. To fix the HDD plug it in to a PC and initilize it. (right click my computer, manage, disk management, right click on drive, initilize. Put it back in the machine.) Should solve the problem.
Apr 27, 2010 | Ricoh Aficio 1035 Copier
I have a Samsung SyncMaster 793.its qwidth is not normal..
Check its B+ supply line it could be low voltage problem. Or check it other component connected to h-width circuit could be a short in transistor, diode or dried up capacitor. Also resistor for overresistance than marked resistance.
What its B+ supply. From schematic I found, I could assume its around 80Vdc.
Can you post its chassis number.
Mar 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
k24674
jasbo
jasbo
