Question about Yamato AccuWeigh PPC-200W Digital Washdown Scale 40 lb
What does the "L" mean on the display? - Yamato AccuWeigh PPC-200W Digital Washdown Scale 40 lb
What does df on interior display of pioneer split heat pump system mean?
In defrosting mode, The LED displays “dF” or alternative displays between running frequency and “dF” (each displays 0.5s)
This means the outdoor unit is in defrost mode, heat pumps will initiate defrost upon demand. Its a normal operation code
Mar 01, 2017 | Heating & Cooling
What does it mean when there's an hour glass on the display? It stopped running last night and there's an hour glass?
It means ''wait'' (seriously).
The question is: ''why is it displaying that message?''
If it is _still_ displaying that message. Try unplugging it for 24 hours.
If after that it _still_ displays that message, you may have a bad computer board.
May 18, 2015 | Dryers
What does an O F fault code mean on a frigidaire refrigerator mean
Sounds like off to me. An open sensor will be displayed in either the ff display or the freezer display. if it is an open freezer sensor it will display in the freezer display. A communication failure will show as a SY CF, and a communication error will display a SY CE.
Feb 18, 2015 | Frigidaire Refrigerators
Samsung c3322 white display
Do you mean the screen is white? Because that means your device is "hard bricked"(a stage that means corrupted inside, or faulty hardware, this means it could be your phones hardware, or a important part of your phone is corrupted), or maybe the display flex or cable in your phone is broken or misattached.
Mar 14, 2014 | Nokia 7230 Cell Phone
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
What do you mean if minolta copier display the simbol of srew drive
it means that it need professional attention. on some models it can only mean the machine is asking for a service. if there is also a code on the display, it means that something has gone terrably wrong and you will need a professional tech to solve the problem
Jan 19, 2011 | Minolta Office Equipment & Supplies
Display only works when it is flipped over
hi, if i understand wath you means that is the pallet
doors display switch /when you flip the panel display
theres a switch in the display doors thats makes the display turn upside down to viewed correctely
i get this problem with different cam i got to fix
that mean :repair is need ,
hope that will help
Mar 09, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
What does a G in the top right of the display mean
It means nothing to you. It just means that you are in a group. It could be an operator group or a paging group. No need to worry about it. The only way to get rid of it is to remove yourself from the group.
Nov 11, 2009 | Avaya 6408D+ 8 Button Display Telephone
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Yamato AccuWeigh PPC-200W Digital Washdown Scale 40 lb Logo
64 people viewed this question
Top Yamato Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Yamato Measuring Tool and Sensor Expert? Answer questions, earn points and help others
