Question about LG 42PX3DCV 42 in. Plasma EDTV
HALF PICTURE ON LG PLASMA MODEL 42V7
Set given to me with no picture only sound , replaced with kit of boards for this fault, common fault told . now have good picture on top half of the screen and very faint red and green picture on the bottom half. not sure what to check new to plasma tv's so any help would be great.
  • Anonymous Oct 21, 2007
    Have checked all cables and changed the control pcb , still the same , service manual is very poor a explaining the PDP part of the tv . suspect the the fault is to do with the plasma control itself, but not sure which panel controls that . or is there some adjustment required as I have replaced some of the pcb's .Any body know which panel controls the plasma ?
  • Anonymous Mar 24, 2014
    You can still see the picture but it is behind a half screen of red.
  • 105 Answers
First check all of your ribbon cables. then check the lvds cable. if this dont fix then you will have to get a service manual and run the panel by itself to determin wich circuit your problem is in. any questions feel fre to contact me....
Posted on Oct 17, 2007
  • Anonymous Oct 22, 2007
    sorry but there arent any adjustmensts that will fix this. th issue you are experiening is a signal issue. this issue could be in the logic main board, th y susain board, or the lower y sustain buffer board. th only way to know for sure which one is to use an oscilliscope.
    send me an email at [email protected] and i will give you a manual that will be helpful to your problems
SOURCE:
My LG TV 32LA6130, has no sound and no picture. Technician is told me to replace the dispaly panel which a cost of Rs.13K
No picture and sound denotes a fault in its main power supply regulator board. Not with the display panel. If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are almost similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts/
May 20, 2018 | LG Televison & Video
My LED TV has the picture in two equal vertical sections with the right one having lower black level and that is for all inputs and even with no input , the black screen is half black and half gray
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 21, 2016 | LG Televison & Video
How do I fix a LG plasma tv that has sound and no picture.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 15, 2016 | LG 50PT350 50 in. Plasma TV
LG 50PK250 shows only 1/2 top screen while the bottom 1/2 screen is black which board do I need to replace??
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 08, 2015 | LG 50PK250 50 HDTVReady Plasma TV
LG Plasma has sound but no picture
Hi James,
This could be one of two problems. I can't narrow it down any further without having the set in front of me.
1. The plasma panel or the componets which supply electricity to the plasma in the panel have packed up.
2. The video processing unit in the set has gone.
As for the cost of repair, if it's the panel, buy a new TV. It'll be cheaper. If it's the component that supplies the electricity to the plasma on the panel or the video processing unit, expect to pay between 300-400 as a conservative estimate for parts. Labour would be another 100-200.
Hope this helps
Apr 28, 2009 | LG 42PX5D 42 in. Plasma HDTV
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Plasma tv has sound but no picture
Check all the cable connections at the back, if you are using an external receiver , then check the Video cable, eventually try a replacement one.
Try leaving the TV set unplugged for a couple of hours, this will drain power completely and, if there is no real fault , this can fix the problem.
If that does not fix it, then thereis an internal fault.
Common faults that cause audio but no picture concern, digital board, controller board, sustain boards, Plasma screen ribbon cables, and plasma display.
Call the number listed on the owner manual to get assistance.
If the warraty is expired no longer than three years, ask the price fod r a warranty extension calling same number in the manual.
Nov 22, 2008 | Televison & Video
Multi coloured vertical stripes on plasma screen
With half of the screen working, and with a Plasma tv. I will look at the driver board as being bad. Take the back cover off, the driver pcb will be at the top or bottom of the set. They are only about 2 inches tall and will cover most of the lenth of the set (2 boards that run end to end). The board that is on the side of the tv that is bad is the bad board. Replace that board or have a tech replace it.
Nov 15, 2008 | LG 42PX5D 42 in. Plasma HDTV
NORCENT PT -4233
Norcent PT4233 no picture, black screen, but has sound. How to repair
The display (PDP - Plasma Display Panel) at the heart of this unit is a LG 42V7 model. There is a known bad solder "defect" on the YSUS board that causes this board to fall unexpectedly.
The bad news is that you have to replace all the primary boards on the display - ZSUS, YSUS and CTRL boards, as the failure can/often takes them all out.
The good news is that LG makes a repair kit for this panel. Its part number is 687VSNB03E and it contains the three boards LG6871QYH036D (Y SUSTAIN), LG6871QZH041B (Z SUSTAIN) and LG6871QCH053G (CTRL).
Hope this helps
Sep 04, 2008 | Norcent Technologies2703 27" TV
LG 42PX3DCV 42 in. Plasma EDTV Logo
356 people viewed this question
Ekse
RONALD CARTER JR
