It's a duke broiler in hungry jacks every time it discharge product it start beeping saying some gas message on desplay and get stopped when we press enter button couple of times?
CoachTim
  • 202 Answers
SOURCE: cannot make copies
gammi, unplug the printer and unhook it from the computer. go to this site: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=60259&lang=en and download the latest drivers. Uninstall the old drivers from the machine. Shut the computer off. wait a minute or so...reboot install the new drivers, XP will prompt you to plug the printer back in and that should work. Let me know what happens, Thanks Tim
Posted on Feb 15, 2007
  • 138 Answers
SOURCE: CARTRIDGE ALIGNMENT
See my post on this issue under the link posted below. There are a couple solutions for this error and we are approaching it there.
http://www.fixya.com/support/t999608-align_cartridges_keeps_comming
Hope this helps you.
Posted on Sep 04, 2008
leroyal
  • 2120 Answers
SOURCE: receiving error that need press enter to align cartridge
Probably not the scanner. Are the ink carts new GENUINE HP cartridges?
Posted on Jan 31, 2009
MUKHTAR
  • 2017 Answers
SOURCE: front panel on printer says align print cartridges
just remove the align page first and then insert in scanner and then clik on scan button and finish it .it will not ask u again.
Posted on Sep 08, 2009
SOURCE: Display message won't stop: Press Enter to align cartridges.
My HP6100 officejet all-in-one printer will not align the print cartridge. I pushed MENU then 7 and the display said, "starting task" and nothing happens. I can't get the printer to print. It will make copies but it doesn't print anything. HELP!
Posted on Sep 13, 2009
I have a Maytag super capacity oven and my broiler is staying on even after I push the off button
do you it beep when pressed if so keypad good next test best to have oven pulled out next time this happens while pulled out unplug I know the ignitor will stop glowing what I need to know does the gas valve shut off may take a few seconds if so then relay is stuck on control board
Feb 13, 2015 | Maytag Kitchen Ranges
1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
Jun 26, 2010 | Magic Chef Kitchen Ranges
Dell inspiron 530s won't boot up and gives me 4 beeps a pause, 4 beeps etc.
4 Beeps indicates a RAM memory failure. Disconnect power, press and hold the power button to release all power from the motherboard, then re-seat the Memory.
If error doesn't go away, try modules one at a time to find the bad one
Dec 27, 2009 | Dell Dimension 8400 PC Desktop
Car wont start some times displays key with a slash
its probably a scircuity problem most likely because it seem with those cars you need the controller in or close to you for the car to start so maybe the ecu or pcm isnt picking up the signal or maybe change the battery on the remote?
May 21, 2009 | 2007 BMW 525xi Sedan
Gas oven is starting by itself
You will have to replace the ERC. Electronic relay Clock.
Feb 22, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Problems with 640 duke starting,not a battery fault any ideas?
remove the sparkplugs and ground them to the engine try to start check for spark at plug if sparking check for compression put your finger over plug hole try to start if it pops off check carb for gas (didnt say if it was running and then sat for a while) with spark and compression and good gas it should run if your finger dosent pop off then the problem is no valve movement to create compression(broken cam chain) that would allow the engine to roll over quickly or whirr as you said check these things and let us know
Jan 04, 2009 | 2003 KTM 640 Duke 2
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Jenn Air F7 error msg with incessant beeping
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
I want to leave my own answering message on my voicemail, how do I do that?
Press Menu. Then the unit will say "record outgoing message" Press the REC/Memo button and the unit will say "recording" and beep. The display will start counting in seconds. Speak your message. Press the play/stop button to stop recording the message will be played back to you.
Sep 22, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
13 people viewed this question
jasbo
jasbo
