Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
Model#fl23r electric fireplace heater shuts off after 5 seconds
How can I replace electric fireplace heater switch?
not a lot of info make and model would be good, try the link below as it does show how on one model.
press the helpful button
Re post with info and question if not helped
How to Replace Electric Fireplace Heater Switches Electrical Repairs
Jan 26, 2016 | Heating & Cooling
My fireplace keeps shutting itself off never done this before
Is this a gas fireplace or electric? If you would post the make and model that would be a big help. IF it is gas then it has a flame sensor in it and those get dirty.
Jan 06, 2015 | Leisure HOMEPRIDE Electric Fireplace...
Noisy fan on electric fireplace
My recommendation would be to contact a fireplace showroom that sells electric fireplaces. It would be best if you could inspect your fireplace for the sticker that identifies the fireplace's brand and model#. The primary concern is contacting a showroom that is able to order parts for that brand...
Mar 17, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
I turn my fireplace on and it works fine until I turn on the heating system it stays on for 5 minutes and then shuts off after a while it comes back on and then turns off again. Who can I call for HELP it...
try to find the thermostat in the fireplace, it's obviously got one that's turning it off when the room temp rises.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Sunbeam fl23r electric fireplace when u turn it on it clicks and shuts off. Will not turn on ir heat up
Wrong wrong wrong. Sorry guys. The fan motor is being overloaded. They have thermal fuses in them that break the circuit the fan isn't dissipating the heat or if there is too much current being pulled. You need to disassemble the fan motor and clean the bearings. I did it with a friend and it took about an hour. It is possible to disassemble it and grease everything up. You need to pull the fan blades out and grease up the axle. That is what solved our problem.
Oct 20, 2010 | Heating & Cooling
Marco gas fireplace, pilot comes on, fireplace fires up, after one minute the whole system shuts off. Why does it shut off after a minute?
Hi check pilot is clean , check the volts from the powerphile should be 300 to 500 mille volts ,seeif pilot flame is playing on powerphile
Mar 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
29 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tim Whalen
Mack Baxter
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
