Question about Music
My Yamaha digital piano ydp 140 had a few keys had no sound. 3 octaves of note G and 3 notes of C# not working. I live on an island the piano is use for island schools. Is there anyway I can fix it by myself or a technician thats around fixing radio and tv can do the fixing?
hamhm
SOURCE: Yamaha digital piano clp 170
This is a common problem with Yamaha keyboards. The problem is caused by worn-out rubber contacts in the keyboard assembly. In my old Clavinova CLP-500, there was one long rubber contact strip under the keys with two parallel strips of semiconductor material. The Clavinova circuitry determines key velocity by measuring the timing between when the key hits the first and second strips of semiconductor material. The harder you play a key, the less time it takes the key to hit the second semiconductor strip after hitting the first.
After years of playing the keyboard, the keys eventually cause tears in the semiconductor material and this messes up the timing measurement for key velocity. The only solution is to take the keyboard apart and replace the rubber contact strip with a new one.
I got rid of my CLP-500 four or five years ago and got a new CLP-170. The CLP-170 is now having exactly the same problem that the CLP-500 had. Yamaha has re-designed the rubber contacts in the CLP-170 so that there are now eight individual contact strips instead of one long one. The problem is essentially the same, though. You have to take the keyboard apart and replace the worn out rubber contacts.
Here are the part numbers for the rubber contacts that need to be replaced in the CLP-170: V8286600 Rubber Contact, 12 keys, D-C#   Qty. 6 V8286800 Rubber Contact, 11 keys, A-C#   Qty. 1 V8286700 Rubber Contact, 5 keys, D-C   Qty. 1
I suggest you also get a copy of the CLP-170 service manual, part number 001677. It has descriptions of all the steps necessary to take the thing apart and put it back together again. You'll also need a "rod" (which is just a long dowel), part number TX000670. Before you take the circuit boards off the keyboard assembly, you have to insert the dowel between the keys and the frame to keep the keys from falling back and getting in your way. A 5-foot long 1/4-inch dowel will probably work. (I haven't yet taken apart my CLP-170, and I don't have Yamaha's "rod," so I'm not sure if 1/4 inch is the right size or not. I'll report back here if it's not.)
Good luck, Howard
Posted on Sep 27, 2008
  • 3 Answers
SOURCE: I have a Yamaha ydp-121 88-key piano. It has 3
I wrote up and photographed for my similar YDP, see solution 2 under this post:
http://www.fixya.com/support/t8881187-1_key_not_spring
Posted on Jul 02, 2011
caroldon
  • 17130 Answers
SOURCE: keys on yamaha digital piano
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Posted on Jul 05, 2011
  • 5603 Answers
SOURCE: My yamaha ydp-160 sounds like
On SOME Yamaha pianos, there is an electrolytic capacitor 1mfd/50v that becomes leaky and causes this. On those with the particular main board the capcitor is at location C94. On other pianos there are other caps that bypass the wire from the pedals that are ceramic. Likely one of these has shorted. There is also a possibility that the pedal contact has shorted. Test for this by unplugging the pedal cable. If it still sustains, then problem is internal. Unless you are adept at electronics this is NOT a DIY repair.
Posted on Aug 07, 2011
rokrgyrl
  • 6 Answers
SOURCE: playing certain 3 or 4 notes at a time causing sound of one or more extra notes.is there a quick fix?
Have a professional tune it for you. It may be that some strings have loosened/tightened.
Posted on Sep 14, 2012
When I hold in C and then press Csharp in the same octave,the C-sharp goes silent.It goes the other way around as well.They work when I tap them separately.And that problem occurs in every octave of the...
It sounds like the piano is in mono setting. One note at a time can be played. Find out how to set it at poly mode, allowing multiple notes to be played at the same time.
Jul 09, 2014 | Yamaha P-155 Electronic Piano
3 key notes not working and can't write my savings to the banks..
Hi, You can reset your whole keyboard by holding down the top C ( highest key ) whilst turning on.
This is unlikely to clear 3 non working keys. My guess is that the contacts under the rubber switches have worn or dust is under the contacts. You could try cleaning first under the rubber contacts if this fails replace the contacts ( 1 per octave ) Part WF212202 contact me if you need more information
Pictures attached may help 0482dd26-e9cb-4b61-b47e-f97d90aa782c.jpg 42e5c956-fedc-40b9-ae04-8bf3e98b22a2.jpg
Mar 28, 2014 | Yamaha DGX-640 Portable Grand Piano...
G# and A# Ghost Notes!
First try looking in your transpose settings. Refer to your manual to see if any arpeggiation/unnatural chord settings were inadvertently created by you or made by another user. If you believe it is a software problem you can not solve, back up your memory bank, remove your memory card, and hard reset your keyboard. Insert your memory card and check to see if your problem still exists.
If it is a technical problem, it sounds like you may need to get it checked out by an engineer/repairman. Sometimes when a digital keboard's keys collect too much dust/debris they can trigger multiple keys that aren't being pressed. Think about it like a key getting caught on an upright piano and pulling back the hammer next to the one that was played. A digital piano works off of one or several printed circuit boards or PCBs. The printed circuits usually can not short circuit because the wires and circuits sit in fixed positions. If an alien conductive fiber or series of conductive fibers connects a conducter to another, or if there is any humidity inside your piano it may cause circuits to misfire when a circuit is connected in the area. This could explain why notes you are not playing are being activated in the area in which you are playing.
If you are in a humid area and you suspect that this may be the cause you can attempt to draw out the humidity before getting a an expensive diagnostic done. Find a box large enough to house your keyboard. [If it is on a stand take it off and] place it inside the box. Cover the keyboard with plastic wrap (so as to prevent any foreign objects from getting into the instrument) and very carefully surround the piano with white rice. Remove the plastic wrap, close the box and leave it alone for a few days. The rice draws out any moisture from the electronic components. Very carefully (again so as to avoid getting any rice inside it) remove the keyboard from the box; remove any dust from the body, face, keys, and other components. Try your keyboard now. If humidity/moisture on the PCBs was the problem it should be solved. If not it is time to take your piano for a tune-up.
Hope this helps!
Jul 12, 2013 | Yamaha Music
Playing certain 3 or 4 notes at a time causing sound of one or more extra notes.is there a quick fix?
Sep 06, 2012 | Yamaha P95 Digital Piano
Hello, I have a Yamaha P90. 4 keys are not responding. all others are ok and give sound. What happened ?
If they are the same note- different octave- it may be a bad solder joint near the main oscillator IC.
If they are the same cluster (adjacent white keys or adjacent black keys) in the octave, it may be a faulty wire connection.
Apr 01, 2012 | Yamaha P90 Digital Piano
My yamaha ydp-160 sounds like my pedal is stuck down. All keys are sustaining all notes. Is there an easy fix?
Aug 07, 2011 | Yamaha yDP S31 ARIUS Console Piano
I'm using the Yamaha P-85 Digital piano. Unfortunately it has lately had some problems. When I'm playing to notes next to each other (especially e and f (mi & fa) or b flat and b (si & si...
In playing fast you have to make sure to release the note fully and let the key come up. These keys have TWO contacts that are used in the scheme to measure note velocity. If BOTH contacts don't open, the note will NOT re-fire. The second symptom you have written would be a characteristic if one of the disconnect diodes has shorted. These diodes direct the strobe signals that scan the matrix of key contacts to avoid other octaves responding when multiple keys are depressed including those in other octaves. Servicing of the unit is required. It is unlikely you have the tools to DIY this problem. ONE THING to try is to tip the unit and gently tap it to see if some debris MIGHT have fallen in that may be shorting some of the matrix connections.
Apr 25, 2011 | Yamaha P85 88Key Portable Digital Piano
Yamaha Electronic Piano- certain notes malfunctioning
Either the first or second closure matrix line for the "A" keys is bad.
This may be a cracked or shorted circuit board.
A bank of diodes is used to prevent sneak electrical path if more than one octave has notes pressed.
First thing is to clean ALL the key contact areas and the conductive rubber pills with 99% isoprophyl alcohol.
This involves dis-assembly of the key area. If you are not competent in electronics, best left to a pro shop.
The keys are scanned in a matrix, two contacts per key and all the individual notes are in common (all the "A;s", "B's"...) And each octave is strobed for the first set of contacts and then for the second set of contacts. an the whole octave is read in parallel.
The reason for two contacts is one closes first and then the other as a key is lowered. The time between these is measured and is the note VELOCITY which for a piano controls the loadness of the note. IF ONE of the two fail, the loudness will vary as yours does.
Nov 24, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Yamaha ydp-121 88-key piano. It has 3 keys that are sticking. Any ideas how to fix it?
Oct 20, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Jan 04, 2009 | Yamaha Full-Size Keyboard
Music Logo
75 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
