Ge adora washer new belt installed as burning rubber smell and puffs of smoke, now works great but very loud, cleaned lint trap and found what appears to be an interior part (plastic in shreds and 2 chunks of metal) corroded and worn...HELP
  • 27 Answers
SKIP
Posted on Oct 21, 2013
  • steph
    steph Oct 21, 2013
    WHAT DOES THAT MEAN?
2 Suggested Answers
SOURCE: Foul Smell from my GE Adora Washer..!
Having the same problem as everyone else , I make a habit of cleaning the filter once a month. I would like to advise people that if your load is heavy (such as scatter rugs) they will not spin out completely even when the filter is cleaned. No more GE for me!!
Posted on Sep 03, 2008
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
Bosh SHY56A Dishwasher - Loud Pop and Smoke While
Hey Matt,
Dishwashers are not that complicated.. Turn off the breaker, pull the machine out - away from the wall..(there will/should be at lest two screws in the top edge holding it to the counter.. remove them first.. then pull it out until you can turn off the water supply.. When you are able to completely remove the washer, you should be able (possibly)to see what happened.. Check to see if the washer arm (inside the washer) will turn, if not.. replace the motor.., check to see if the pump belt will turn?.. it could be the pump drive motor or the pump its self..(remove the belt), then see if the motor will turn, check to see if the pump will turn.
.. White smoke makes me think that the belt was turning and the pump NOT turning..that will cause the belt to smoke.. and smell like burning rubber..If the pump will not turn. you have found t he problem... Also ..Check to make sure there is not a knife or some other object lodged in the drain or pump
NOW -- With all this.. Sometimes REPLACING the machine is actually cheaper than repairing the old one!!! Your wife deserves a NEW one!!
Jun 28, 2017 | Dishwashers
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Smelled like something burning, then quit working
clean lint trap out more often after every load and try to vacumn inside lint trap lint tends to slip down below the trap and yes it will ignite from time to time My gas dryer did it once and yours it smoked and stunk but because I was home it never went furtherif you open bottom front panel if your machine has one you can get a lot of old lint cleaned out there as well...and most dryers post in their manuals the risk of lint fires
Dec 18, 2009 | Dryers
My MLG2000AWW today after the wash cycle was done a smell of burning rubber and a little white puff of rubber smoke comming from around top front edge of washer tub in front. Need some help in...
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. The smell of burning rubber probably came from a slipping v-belt. Good luck with it.
If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Washing Machines
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Apr 10, 2009 | GE DVL223EBWW Electric Dryer
97 cad sls white smoke near windshield smell like rubber burning
If its in the engine compartment there is an antifreeze leak..If it inside the car like like near to the windshield, you have a bad heater core. Good Luck contact me if you need more help.
Dec 25, 2008 | 1997 Cadillac Eldorado
Aug 21, 2008 | GE WSXH208A Front Load Washer
GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Oct 29, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
