Question about Briggs Stratton 7,000 Watt Automatic Home Standby System with 50 amp
My 7kw home generator when turned on just clicks ? What could the problem be
    New Friend:
  • 17 Answers
Your battery is dead. The B&S generators take an AGM style battery, you can get one at Interstate. Use the 35 amp-hr model.
Posted on Oct 25, 2013
Briggs and Stratton 7KW House Generator can not start. Model 01897
You may be experiencing the major short fall in CNG & propane systems. The gas regulator. They are unforgiving. If used every day they stay clear and last forever. But intermittent use allows moisture to form & oxidize internal components. Valves & diaphragm start to malfunction and then the safety design of the regulator prevents it from working unless all is well. I'd be willing to bet this is your problem. Good luck.
Sep 15, 2015 | Briggs Electrical Supplies
Why does my briggs and stratton 310000 run rough on startup?
look for fuel puddling in the carb area (strong fuel odor on start up or after primering) may need a needle and seat valve
Jul 11, 2014 | GE 7KW Generator System With 50A, 10...
Cant run both a/c at same time
A 5KW is too small to run two HVAC at once, especially if they do not have interlock relays where only one at a time can cycle. It needs a 7KW for two HVAC units
Mar 16, 2014 | Onan 5500 Microquiet Generator
"briggs and stratton 7kw generator will not stay running
check fuel filter . check oil level. check oil level sensor circuit for broken /loose wire. check for vent blockage in filler cap. clean air filter and make sure that the choke lever is tight enough to stay off then warm
Aug 11, 2013 | Briggs & Stratton Electrical Supplies
I have a Briggs and Stratton 7KW standby generator. I accidentally spilled some oil on it during a hurricane and cleaned it. However, when I try to start it, it will go on for about 15 seconds and then...
sounds more like a fuel problem not oil being spilled on it but check the oil level some have a low oil shut off see if you can keep it running spraying carb cleaner in the air filter that will tell you if it is a fuel problem more so a fuel problem if you left fuel in it for more than 30 days
Aug 14, 2012 | Briggs & Stratton 15,000 Watt Home Standby...
My generator is a briggs and stratton 7kw prowered. connected to full propane tanks. i have not had any problems with the generator until this past weekend. the generator starts up fine, and then once...
You have a fuel delivery issue that can be dealt with by cleaning carb or replacing it. If you do replace carb has to be adjusted to the motor.(idle, mixture)
Sep 03, 2017 | Briggs & Stratton Briggs Stratton 7 kW...
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
May 01, 2010 | Briggs & Stratton Power Products 5,550...
Briggs Stratton 7,000 Watt Automatic Home Standby System with 50 amp  Logo
131 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
rlev_7
Level 1 Expert
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
