Question about Sharp Office Equipment & Supplies
I replace toner for sharp ar 5520 and the toner steel low ..... help please
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Open and close front cover again
Posted on Nov 12, 2013
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 5 Answers
SOURCE: U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
Posted on May 27, 2009
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
  • 26 Answers
SOURCE: sharp ar 5520 fault code
F2 40 = ATC sensor abnormality
Check e remedy :
Remove/Install the toner cartridge again.
Replace the toner cartridge with a normal one.
Posted on Sep 07, 2010
CH blinking in sharp photo copyier model AR 5520
check if the toner is insert or check the doors for the machine both the front and side door door
Nov 05, 2016 | Sharp AR-5520N
SHARP AR 5520 keep displaying TONER INDICATOR ALARM MESSAGE whenever I switch on the copier. And even if there is toner, the message keep displaying. So what is the problem?
Dear
The ink cart. is dual component one is drum unit and other is toner unit. You may go to system information there consumable information which indicate the status of the both and according to that replace the chip of the respective cart.
Thanks.
Jan 12, 2015 | Sharp Office Equipment & Supplies
5520 sharp ch eror
If CH is still ,your machine's side cove or front cover is not Fully close.
If CH is blink, Toner Cartridge of toner chip is out of your machine, Or toner chip is damaged
Feb 11, 2014 | Sharp AR-5320 Black and White Copier
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5520 fault code f2subcode 40
Check e remedy :
Sep 06, 2010 | Sharp AR-5320 Black and White Copier
May 23, 2008 | Sharp AR-M237 Copier
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
