Question about Husqvarna Viking 1
Hi I have a Viking Husqvarna 6360, and although
Hi I have a Viking Husqvarna 6360, and although it all seems to be working fine smoke soon pours from the motor area once its fired up. I've taken off the motor cover and made a visual inspection: at the back of the motor, just visible, is a small electrical looking gizmo, about 2cm by 1cm by 1cm, with this number on it: PZB4003/13. It looks exploded and is probably the source of the smoke. What is that gizmo, and how do I replace it? Cheers.
    Champion:
  • 208 Answers
Dead right, the part you can see is a suppressor which on most machines you don't need these days, snip it off, id the machine does not work when you have taken it off you can get the part from most sewing machine shops
Posted on Oct 21, 2013
  • Dom Shad
    Dom Shad Oct 24, 2013
    Perfect, thanks. I removed the motor, snipped off the offending article - a metallized paper capacitor, or suppressor - and replaced it with an updated version supplied by the wonderful and patient people of Coles Sewing Centre of Nottingham (no connection).
  • 192 Answers
SOURCE: Bobbin Case Assembly
Careful now, don't get in too big of a hurry.
The back side of the hook cover, which holds the hook in place in this machine is supposed to have several grooves in it. If there are no cracks, it's probably ok. The hook should also have a considerable amount of movement, or clearance when the cover is in place. Take that away and it won't sew at all.
The most common noise I hear in these machines is a buzzing or moaning sound from the bobbin area. If this could be an apt description of your sound, remove the bobbin case, roll a cotton swab between your fingers until it will fit inside the center post of the bobbin case and clean it out with alcohol. Allow it to dry completely and then put one drop of machine oil inside this post, place it in the machine and run it. The sound should be gone.
Posted on Jan 14, 2008
  • 11 Answers
SOURCE: user guide Overlocker/serger Husquvarna Viking Huskylock 905
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 24, 2009
  • 152 Answers
SOURCE: Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Posted on Oct 07, 2009
  • 152 Answers
SOURCE: Designer I software compatibility
You need the Husqvarna Viking software to turn those file extensions into the SHV format. It's about $400 at your dealer. Their web site does a nice job of showing its features. You get over 100 fonts and alot of designs too. You would open your current designs on a screen and then re-write them to the floppy or stick depending on your model of D1. It then sends the stitch information with the picture of the design to the floppy so your D1 can display the image. (The SHV format)
The VIP and HUS format don't carry the image file for your machine so it say's, "file not found", when you try to open them in your D1.
Posted on Oct 24, 2009
  • 371 Answers
SOURCE: Husqvarna Viking Prisma 980 pop then smoke, but still works
Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
Price removed casing round bobbin and inner case to clean fluff , now I carnt seem to line up properly although all slots back the needle won't go down properly .....husqvarna Viking E10 ..man
Remove bobbin case completely and check that the needle will go down properly. If so, put the bobbin case back in lining up the black arrow on the bobbin case (on left hand side) with the metal arm that comes out slightly on the left side. Sometimes, it is tight getting the case back in place properly. Once in place, check that the case will rock back and forth slightly.
Hope this helps.
If you are still having trouble, most Viking dealers will be glad to assist you in the store. You can find the Viking dealer nearest you using Locate a Dealer at the Husqvarna Viking website -
http://www.husqvarnaviking.com/us
Oct 17, 2014 | Husqvarna Sewing Machines
How do sew a straight line on a viking 6360?
You may need to service the machine. One thing to check is the feed teeth are at least 1mm above the needle plate on the highest setting. You can remove the needle plate and check if there is lint keeping the teeth from rising. The upper right knob controls the stitch length set it at 3 for normal sewing. 6 would be a longer stitch.
Jan 19, 2014 | Husqvarna Viking 1
Husqvarna 3610 doesn't pick up lower thread
Hi, Check to see if needle is bent. If the needle is bent it will not work well and soon it will break.
Replace the needle. Also lube the moving parts on your machine. (fine oil) sold in most sewing centers.
Jul 24, 2011 | Husqvarna Viking 1
Vista cannot locate the drivers for my Viking reader/writer; although it worked fine two weeks ago.
There is a vista update on the Husqvarna site, which can be downloaded.
Dec 08, 2009 | Husqvarna Viking 1
I have a Husqvarna Mega Quilter Viking. The
If you're sure you're using the correct needles, you should take it to a service tech to align it properly.
Nov 01, 2009 | Husqvarna Viking 1
Sep 19, 2009 | Husqvarna Sewing Machines
Good luck.
Apr 11, 2009 | Husqvarna Viking 1
Husqvarna Optima
If still an issue, suggest you visit an authorized Husqvarna Viking dealer for assistance. They are usually eager to help. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jul 23, 2008 | Husqvarna Lily 540 and 550
Husqvarna 5710
Good luck.
Mar 29, 2008 | Husqvarna Viking 1
Sewing Machines Logo
220 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
