Question about LG Electronics LRM-519 Digital Media Recorder
Unit not responding
Upon starting, the unit displays welcome and does not respong to inputs. The DVD tray will not open and the menu screen will not come up. Any assistance that can be provided would be appreciated.
  • 7 more comments
  • Anonymous Nov 11, 2007
    When I turn mine on, it displays "Hello" on the screen and nothing will happen. I can't open the dvd tray or anything. Any ideas would be greatly appreciated.
  • Anonymous Nov 27, 2007
    After 2 years of working, my unit has stopped, when turned on the Display shows Hello and DVD will not open. This happened when I unplugged the unit to move it, when I plugged it back in, it stopped working.
    I was advised by customer support to unplug for 30 secs then plug back in while holding the "stop" button on the unit for 30 secs. Didn't work! I was advised to try a hard reset which if worked would delete everything on the HD. When plugging the unit in, hold "stop" and "play" for 30 secs..still nothing.
    Anyone have any ideas on how to fix this problem yet?
  • Anonymous Dec 02, 2007
    I have two units that have both stopped working within two days of each other. Mine hangs showing "hello" but nothing happens. I have looked at the hard drive and it is working on my PC, so that is no the problem. Still searching...
  • PinkyPants Dec 03, 2007
    I had the same problem as mentioned above, however I noticed I could hear a quiet ticking sound from inside that corresponded to the subtle flashing of the "Hello" in the desplay. When I took off the cover, I saw a tiny red flashing light on the left side of the motherboard, which produced the sound. Next to it is a nicad battery, and two little red buttons, one marked by a + sign. When I pressed them, one made the light speed up, the other made it stop, but nothing changed. No hard drive spinning up, no change in display (aside from the flashing stopping), no opening of the tray. Any idea what that is all about? Could it just be that the battery is dead? I'll call tech support tomorrow and try replacing the battery and let you know.
  • Anonymous Dec 04, 2007
    I have had this problem for a month. Has anyone come up witha a solution.
  • moghedien Dec 21, 2007
    The last two times I've had to unplug the LRM-519, it has gotten stuck at "HELLO" When I opened the case and powered up, the green LED 800 lights up and stays on, the red LED 801 lights up for a second, then goes off. There is some sound of HDD activity, but it shuts off when the red LED does. Then fan comes on at this time, but it also shuts down. I have powered down the machine by pressing the power button for five seconds, then powering up the LRM-519 to no avail. I have also replaced the lithium battery which made no difference. Luckily, the machine came back to life, but I'm afraid the next time I have to unplug the unit, it might not come back. If the unit has a bad power supply(as some others have suggested), can anyone here suggest a suitable replacement?
  • Gary Clevenger Jan 08, 2008
    mine problem is pretty much the same, I noticed on powerup the fan starts to spin up (about a second) then it stops and the red LED near the battery goes out at the same time as the fan stops, my display has a fain HELLO displayed, the power button is blue and a green LED labeled LED800 (on the circuit board is lit) otherwise the thing appears dead. I think maybe the power supply is failing and shutting down parts of it during power up. Any help would be appreciated.
  • mikemerk Feb 12, 2008
    I have several of these units and also bought one for parts which allowed me to fix one that died. Upon power up front LED would just sit at "hello" with the top cover off I could als see that the fan would just spin for a secone when I plugged it in. I thought it might be power supply related so I looked at the power supply and noticed that one of the capacitors (green one) looked like it was bubbled on the top instead of flat like the rest. Well sure enough I unsolder the same capacitor (not bubbled and flat on the top) from my spare unit's power supply removed the suspect one solder the good one and it worked. I would assume you could get that capacitor at Radio Shack or a electronics store. Worked for me or maybe I just got lucky????
  • dimakatsopet Aug 01, 2008
    My dvd says HELLo and the dvd does not open and once i switch on the lacer flash the whole time till i switch it off. The model is LG LH-CX247W
Not the solution but it has been suggested to remove and replace the CMOS battery. Can anyone help me finding the CMOS battery on an LG RHT387H
Posted on Dec 23, 2012
Thanx for all the useful tips, My problem, pretty similar.
LG LRM-519 tried playing a DVD and POOF... all of a sudden it didnt boot up properly. It would go into "DEMO" mode.
Boot up saying "Hello"
The LG logo would come up, with the dots changing on the tv screen.
Then black screen
then there was a blue line across the black screen and the front display would say "DEMO"
Didnt do anything, couldnt open the disc tray... etc...
Opened the unit up, took out the disc from inside. Then Removed the CMOS battery.
Started the system up with no battery at all in, it said "PLEASE WAIT" then I just unplugged it after waiting far too long (about 2 mins) then put the CMOS battery back in, and voila! My unit was back up. :)
Before more radical procedures .... Try just taking out the CMOS battery.
Good luck all...
Posted on Sep 16, 2008
I powered up while holding the play/pause button on top of the recorder and out popped the dvd tray!
Posted on Mar 09, 2008
A while back my unit suddenly stopped displaying video and sound and the LCD display was stuck at Hello. I had a DVD+R in the drive that was constantly spinning, but would not eject. First, I tried all of the reset procedures listed in the manual and these archives to no avail. Then I took the cover off and removed the DVD+R. Still no progress. So upon the advice of another poster, I put a normal DVD back in the player (through the top with the cover off). This DVD just spun continuously and there was still no video/audio and the LCD still showed Hello. I was about ready to give up, when I decided to remove the CMOS battery. After taking it out for a few seconds and replacing,
I plugged the unit back in and it booted right up...good as new. Been working fine for months since.
Posted on Dec 15, 2007
I have a similar problem.  The system locked-up on me while playing a DVD.  The drive would not open and the system would not shut-down.  I tried unplugging it, but when I plugged it back in, It didn't do anything.  It simply went dead.  I called LG and they said that it souned like the power supply had gone bad.  I also checked the hard drive on our pc and it's working fine.
Posted on Dec 10, 2007
A five pound sledge hammer might get the "Hello" to disappear from the display, and the little red light to stop blinking. Tech support is a joke. I'm calling the friend at Microsoft who gave me the damn thing in the first place and will ask him to fix it. If I find out how, I'll post it here.
Oh, and I tried the other solution, and now the blinking has sped up and won't stop unless I remove the little battery. No idea what that means.
Posted on Dec 05, 2007
I just had this problem for several months. I read your suggestions and none worked. I tried a different sequence. I held the Stop + Pause at the same time and then powered up. With cover off. Held for thirty seconds. Then while the system is powered up I removed the battery from the "J800 socket on the main mother board. I re-inserted the battery. I then did a hard power down. I plugged the unit back in and it went through a start up sequence and said "Please Wait" It appears to be working. Tray comes out and changes channels. Good Luck. Thanks for the inspiration of button pushing??
Posted on Dec 04, 2007
I need to hack the region of the Sony DVD SR500H
Hi there
Follow these steps and your dvd will be able to play discs from any region.
*With the player in stand-by mode (take out any discs and leave it alone for several minutes) press on the remote, in this order: TOP MENU, CLEAR, POWER.
*A menu will appear with several options. Choose Option 2 and then Option 4.
*Type 12450, press enter, then type 00000.
  • Step 4 After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvIMQI5i
    *After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
    Thank you for visiting
  • Step 2 A menu will appear with several options. Choose Option 2 and then Option 4.
  • Step 3 Type 12450, press enter, then type 00000.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvI1JPoD
    Jul 27, 2010 | Televison & Video
    Dvd door will not open
    with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
    This is from page 83 of the manual regarding tray lock feature.
    Nov 18, 2007 | Televison & Video
    How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
    Hi
    Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
    1. Switch power on
    2. Open the DVD tray (leave it open with no DVD in it)
    3. Press "stop"
    4. Press "734466"
    5. Use cursor to scroll up or down until it says "Region 0"
    6. Press "OK/Enter"
    7. Switch power off
    8. Switch power on
    It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 30, 2010 | Teac DV-H500 DVD Player
    Disc tray on RDR-HX720 doesn't open and display
    1 of 2 things
    can you hear the motor running inside the player ????
    there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
    if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
    Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
    Is this dvd player a multi region dvd player?
    Its Not But you Can Make It.
    Just Take Out The Dvd And
    1.Power Off The Unit
    2.On The Remote And Hit Display, Top Menu, Clear, Power A Menu Will appear on The Screen.
    3.Select option 2 (Drive Manual Operation),
    than option 4 (Tray Aging Mode). The screen will show two input lines, each with 5 digits
    4. Change The Top Line To 12450
    5. Then 00000 On The Second Line And Press Enter
    6. The Disk Door Will Open And Close A Couple Times
    7. Repeat Steps 3-5 and enter both Codes As All 00000
    A Long Process But It Works.
    Hope This Helps.
    Sincerely,
    Michael Scott
    Jul 14, 2009 | Sony DVP-NS575P DVD Player
    I have a Cyberhome CH-DVD 300 and put it in progressive scan
    turn on dvd player,leave disc tray close,press and hold in the stop button for five seconds,the dvd player will restore to factory settings and you will see the welcoming screen again,happy viewing watching your favourite dvds
    Feb 28, 2009 | Cyberhome CH-DVD 300 DVD Player
    Will not open the DVD tray.
    if your dvd tray is not open you need a one inch pin or needle into hole..the hole right side .....then your dvd tray open
    Feb 01, 2008 | Samsung DVD-HR720 (80 GB)
    HD-XA1's door won't open
    how do i connect my dvd to my tv with scart leads
    Jan 14, 2008 | Toshiba HD-XA1 DVD Player
    Unit has locked up.
    The only way I got my H340 off the loading was to plug it into the computer through the data port, then unplug it then plugging it in to the media port then unplugging it. Then it would let me go to the menu. I tried to reformat it, nothing just wiped out all my music. I tried re installing firmware, nothing. I hope this helps.
    Jill
    Sep 13, 2006 | iRiver H340 MP3 Player
    LG Electronics LRM-519 Digital Media Recorder Logo
    1,323 people viewed this question
    Computer Repairing
    Computer Repairing
