Question about Tomtom GPS
Satnav520 battery drain out and doesn't charge same time
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
Replace the battery, rechargable batteries don't last for ever, they wear out
Posted on Nov 06, 2013
Hi, I have a 1.5kva cyberpower inverter installed but it doesn't charge the batteries even after displaying the input voltage on screen. It will just drain the batteries and then shut down the output.
Unless a battery is completely drained, over time it begins charging less and less. If your laptop seems to run for less and less time each time you unplug it from the wall, you probably need to reset it. This is a simple process.
Disable all power-saving and automatic shutdown programs or routines on your computer. If your laptop power plan dims the screen or goes into sleep mode after a few minutes of idle time, disable that. Unplug the laptop's AC adapter cord. Drain the laptop battery. You can just use the laptop until it shuts itself off, or you can wander away and come back when it's gone dark. Make sure that you do not turn it off or allow itself to shut down to conserve power; you want it to run out of power entirely. If you happen to be in a hurry, feel free to exhaust the computer more quickly by playing a 3D graphics-intensive computer game or watching a bit of online video content. Plug the AC adapter back in and wait for the charging indicator light for your laptop to come back on. Once you see that the laptop has begun charging again you are free to do whatever you like, so long as you do not turn the computer off until the battery is fully charged.
Feb 27, 2013 | Computers & Internet
What's draining my car battery?
it could be the radio wasn't hooked up right and doesn't turn off when the car is off. Or you could have a broken or chaffed wire somewhere grounding out. either one will drain a battery rather quickly.
Jul 16, 2012 | Volkswagen Golf Cars & Trucks
Ausus U50A power tansition problem
If you are saying your laptop shuts down when you remove the power cord then that's a sign that your battery is dead.
Batteries only have a useful life, then after that they have to be replaced. Once the useful life is up, most times the battery will not take a charge.
Some batteries will take a charge and say they are at 100% but as soon as you remove the power cord it doesn't take long before it is drained at 0%.
Jun 05, 2012 | ASUS U50ARBBML05) PC Notebook
The battery was replaced in April 2011. I have had vehicle for 7 years and only put about 5k miles a year on car. I have never had any issues with starting the car until I replaced the battery. I have had...
A parasitic drain is basically caused by something being left on, but there is a simple way to find out. Once you have had your battery charged an/or have driven for at least 20 mins, you can condust the following diagnostic:
Making sure all interior lights are off, attach a voltmeter to the battery to monitor the voltage.
Locate the fuse panel.
Remove a fuse. Observe the voltage on voltmeter. If it doesn't change significantly, replace fuse and proceed to next fuse until all fuses are tested. Once you find a fuse that changes the volts by at least 2 volts, you have located the circuit creating the drain. Consult your owner's manual to see what accessories that fuse powers, then you can see if the component is stuck on, left on, or is defective. Good luck.
Sep 01, 2011 | 2004 Lincoln Aviator
Hi, I have a problem where the battery is drained. The car doesn't start, no life at all, no power on any circuits, had to open the car manually. The battery volt 7.2 volts. I have had AA out &...
Next step is you need to find out for sure that your battery is still
good (holding charge) and the alternator is charging the battery
when the car engine is running. Use a digital multimeter to measure
DC Voltages: Charge the battery --> should be 12VDC plus. If you can't
get 12V+ (say 10V or less) then your battery is dead. Otherwise,
Start your engine --> should be 14VDC plus on the battery terminals.
If it is 14Volts+ then your Aternator is doing its job, but there is no
guarantee that the battery is holding the charge. Turn ON the head
lights on full beam. After 10, 15 mins shut off the engine and measure
the voltage on the battery. If it is not 12V and voltage still dropping to 10, 9, 8..etc...
then your battery needs to be replaced.
Jul 18, 2011 | Computers & Internet
My battery was was not charged for 2 days over the weekend and now it won't run on batteries. I need to have it on AC power every time I use it.
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=IdeaPad+S10e+battery&_sacat=See-All-Categories
Regards, Chris
Jul 12, 2011 | Lenovo IdeaPad S10e Netbook
My MP313X is about 3 years old. The battery charge only lasts for abuut 25 minutes when it initially shows a full charge then it shuts down and the indicator shows the battery is drained. Can I get the...
If the battery is no longer made by the maker and they can't suggest an equivalent, then the only option is to look around for a second-hand device, or used battery that can still be charged. Otherwise it is time to get a new model.
Dec 29, 2017 | Truly MP313X 1 GB MP3 Player
Battery charge is only good for 15to20 seconds---24volt-----bought aug 2010 ---l24wg165x1p-----serial#45667----please advise soon as possible------j.campbell ---phone419-836-5516------cell...
Your battery has probably just reached the end of it's service life, or developed a memory after repeated chargeings without being fully depleted. All rechargeable batteries have an average maximum number of duty cycles. (drain and charge) If your charger has a deep cycle feature, try using this to completely drain and recharge the battery. If it doesn't, try putting it in your trimmer and locking the trigger back for a few hours, then recharge it. If neither of these work, it's time for a new battery. If you do get a new battery, be sure to COMPLETELY drain the battery before recharging by locking the trigger back every few uses to avoid developing a memory and help extend the life of your new battery.
May 31, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Just bought a usb cord charger for my nikon coolpix s203 and its been dead fir a couple of days and I wont turn on
You left your camera on for a couple of days? I'd think your batteries are completely drained. The S203 doesn't charge batteries via the USB port. Try charging the batteries overnight using the supplied MH-63 charger.
If that doesn't do it, please reply to this post and we'll go on from there.
May 13, 2011 | Nikon Cameras
Phone went through washing machine, has dried out but wouldnt charge
Ferg,
What a pity. Such a lovely phone gone down the drain, almost.
If it stayed in water for that long, at least 45 minutes, it must short circuited all its components. Even if one IC goes Nokia scraps the phone.And in your case you cant say how many.
Are you still hoping for a miracle. Well, recharge the battery. It will take a long time to show "charging" as the battery must have drained completely. After that follow the procedure in the link below.
Got Your phone Wet? - Save It Now.
And I too hope there is a miracle.
Dec 16, 2009 | Nokia 5800 XpressMusic Smartphone
GPS Logo
12 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
