Question about Chips Computers & Internet
Dell inspiron 1545 cd drive
Please how can I locate the usb chip on my dell inspiron 1545 motherboard
  • 1 more comment
  • Falola Adekunle
    Falola Adekunle Oct 22, 2013
    thanks for the answer, my usb port generated liltle spark while trying to clear the usb area with metal object,.... so my usb port stop work.. and i guess the fault is on the motherboard... really wana fix it if possible
  • Dave C
    Dave C Oct 22, 2013
    There is no reasonable way to fix a blown port, except that you might be lucky and have only blown a fuse.
  • Dave C
    Dave C Oct 22, 2013
    The fuses are generally either 0 ohm surface mount resistors on low end motherboards, or surface mount polyfuses on better motherboards BUT the polyfuses are supposed to reset themselves but they don't always. Generally either are positioned right next to the USB port socket or pin header.
    New Friend:
  • 16 Answers
USB is integrated into the chipset, which is under a secondary heatsink a couple inches away from the CPU heatsink.
Why do you need to do this, since it is not user serviceable nor is there any need to physically access or locate it?
Posted on Oct 21, 2013
3 Suggested Answers
  • 38 Answers
SOURCE: My dell inspiron 1300/B130 will not load windows
Step 1 Check BIOS setting to make sure the CD is recognized by machine and is part of the Boot Order sequence. Preferably, the CD should be first in the boot order.
Step 2 Check CD cable connections to make sure they are tightly fitted into their sockets. Also make sure CD is plugged in and CD is getting power.
Step 3. Swap out cable ribbon. Sometimes these go bad. Hope this helps.
Posted on Apr 02, 2010
  • 124 Answers
SOURCE: good day how are you
It would be difficult to figure out what the actual problem is, without having much details. Well, if the Lap is brand new, you will have to charge the battery for a specific period during it's first charge. The time for charging will be clearly specified in your manual. If you have charged it fine and since it is new, I would advice you to make use of your warranty. Go back to your dealer or contact Dell support center. Don't break any seals as it may take off your warranty.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,
Sunny.
Posted on Sep 02, 2011
I need to replace the CD Drive (is that what it's called?) on my Dell Inspiron 1545. Problem is - I can't figure out how to remove the old, original one. I've read that it's supposed to just slide out...
Hi kevin_mills5,
Welcome to FixYa! How are you doing?
I checked the Service Manual for Dell Inspiron 1545 and here is what i found in removing the CD Drive:
  • Remove the screw that secures the optical drive to the computer base.
  • Using a plastic scribe or screwdriver, push the optical drive out of the bay.
You can view the Sevice Manual of Dell Inspiron 1545 by clicking here: http://support.dell.com/support/edocs/systems/ins1545/en/index.htm
Hope that helps. Thank you for using FixYa.
May 01, 2011 | Dell Inspiron 1545 Notebook
My cd drive on my dell inspiron 1545 wont open
Have you tried inserting a needle or pin into the tiny hole that is on the actual pull out piece just below the tab that you would normaly press to open the cd drive
Oct 30, 2010 | Dell Inspiron 1545 Notebook
I have Dell Inspiron 1545 win 7, the eject bottom is not working, so please solve this problem if you don't mind.
You can try reloading drivers for the CD Rom or open ( my computer ) on your deck top or in start menu. Right click the (D:) drive, there will be an option in the drop down menu to eject drive.
Please rate if helpful.
Sep 27, 2010 | Dell Inspiron 1545 Notebook
How much would it cost to install a new cd.dvd drive into my Dell 1545 laptop?
cd/dvd drive component around 50 euros and installation to your local pc store from no charge to maybe 10-20 euros
Mar 22, 2010 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 problem on installation,problem
1. boot to cd/dvd rom using the dell resource drivers utilities. you need to test the dvd drive if it is working, if yes, we might have 2 problems it might be the dvd installer or the hdd. run a test for the hdd to isolate the issue or you can try to run the installer to a diff computer to test if dvd installer is not faulty.
Oct 05, 2009 | Dell Inspiron 1545 Notebook
Computers & Internet Logo
48 people viewed this question
Top Chips Computers & Internet Experts
Alun Cox
cwradio73
Are you a Chips Computer and Internet Expert? Answer questions, earn points and help others
