Question about Kitchen Ranges
Kitchen Aid superba model # KGRT607HBTO Bake function is not working although igniter was replaced a couple of months ago. Broil feature is working.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Pull the temp sensor and with a multimeter, see if you get a reading of around 1100 Ohms at room temperature. Post back the results.
Posted on Oct 21, 2013
SOURCE: Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Posted on Nov 11, 2008
fridgetech
  • 473 Answers
SOURCE: Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Posted on Nov 10, 2007
aborcass
  • 2651 Answers
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
  • 71 Answers
SOURCE: Oven will not bake, but broil works
the bake ignitor is most likley bad
Posted on Dec 24, 2008
  • 126 Answers
SOURCE: Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Posted on Jan 16, 2009
When I turn on the broil function in the top oven, the bake igniter glows. I checked the voltage in the wires to the broil igniter and there is 0 volts. Is this a bad component on the ECB or can the ECB be...
This is probably a problem with the wiring outside of the control. To confirm this, check for continuity on the bake and broil relays upon activation of the broil function. If the the broil relay activates and the bake relay does not then your problem lies outside off the control board. I am familiar with troubleshooting Maytag appliances as I work for a company that repairs appliance timers.
Mar 20, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Broil ok but bake not work
If the model range you have this listed under is correct, the problem more than likely is a bad igniter on the Bake manifold. Each manifold has its own igniter. Since the bake feature gets used more often it tends to wear out faster. The following link explains oven igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Good sources to find a replacement igniter include:
searspartsdirect.com*
appliancepartspros.com*
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best price.
* These two sites also provided excellent exploded view diagrams to assist in part identification and assembly.
If you have any questions about this repair, please let me know. I hope you find this information helpful.
Jul 28, 2009 | KitchenAid KGSC308LSS Gas Kitchen Range
Bake function not working
Yes, you need to replace the igniter.
If you're comfortable splicing wires, you can order any ignitor of the same shape, otherwise go to searspartsdirect.com to find the exact replacement part.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Jul 19, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Oven not working, but broiler is...
Very well could be. I'm assuming the bake burner is the problem, right? Does the igniter glow at all? If it is glowing, but the burner does not light, is it usually a symptom of an igniter that has become weak. If it does not draw enough current the gas valve will not open and the burner will not light. This is a safety feature to prevent free flowing gas without ignition. If the broil burner is functioning properly, then more than likely the gas valve and regulator are working fine. In most ranges both burners are fed from the same source. You could try swapping igniters between the broil and bake burners to prove the theory. Or, you could just replace the igniter all together. Current readings are as follows: Round shaped glow igniter: 2.7 to 3.2 amps Square shaped glow igniter: 3.2 to 3.7 amps If you can give me the exact model number off your range (usually located around the oven door or on the back of the range) I can give you the correct part number you will need. Most appliance repair stores carry the igniter. I hope this helps you.
Sep 14, 2007 | KitchenAid KGST307 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
