Question about Magic Chef 9122 Gas Single Oven
Vulcan hart oven 36L77R-diagram of relighting the oven pilot
How to relight the pilot light on the whirlpool super capacity 465 oven
Rebecca Yount, we're sorry to learn that your Oven will not ignite. We recommend service due to we aren't certified Technicians and wouldn't be able to advise you on how to relight the pilot light on your Oven.
Oct 17, 2017 | Whirlpool Ovens
How to I relight the pilot of the burners on my kenmore 362.72201891 oven. Not the oven pilot but the burner pilot light.
Hello, Thank You for using FixYa. I will be helping you today.There are no standing pilots to light.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Kenmore Ovens
My vulcan burners lit but I can't get the OVEN pilot to light . What are the steps to light the oven ?
use matches,the pilot ligth is hard to replace unless in the tecnician can do,and hard to find the parts.
tnx.gerbee
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
Where is the pilot light located
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Dec 15, 2008 | Frigidaire FGB24L2A Gas Single Oven
Vulcan model 36L77R oven issue
Hi - I had same issue with Vulcan Hart Stove and you need a $16 Thermocoupler part called T46 #VH412788-1 at partstown.com
Took me 5 minutes to install.
Good Luck, we are finally parting ways with our stove as more issues have arisen.... otherwise great stove.
Aug 08, 2008 | Ovens
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
Nov 16, 2007 | Ovens
Magic Chef 9122 Gas Single Oven Logo
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
