Question about Subwoofer Box Single Vented 10" Fits Dodge Quad Cab Durango
How do I open the subwoofer for LG HT762TZ-ZA; it has just stopped working
    Sergeant:
  • 174 Answers
General:U may have turn it off/mute by remote accidentaly.ceck audio settings on the amplifier.Ceck on/off /volume button also located on the sub if apply.Ceck signal from the wiring with another woofer or multimeter (empiric u can do it by small light bulb 6-12v).If still need to open the case,remove the drive mask (textil/metal)by putting little pressure with a flat tool under it,under it should be the screws from the drive itself,can be taped with small caps.The box itself most likely it won't open.Caution:turn off ,work carefully not to scratch,use plastic tools,don't put large amount of pressure,the drive mask should pop easy.
Posted on Oct 22, 2013
My LG HT762TZ DVD/CD receiver is set to zone 4, but I have a number of other zones DVDs. How do I unlock it to play them please?
1. Turn on the dvd player.
2. Press eject
3. Type in 0000 on remote
4. A menu called region edit should appear.
5. Press 0 again for all regions.
6. Press enter
7. It goes to another region code menu
8. Press 0 again and then enter
6. Switch off dvd player and switch back on.
there you go
Jul 15, 2008 | Televison & Video
Get sound and "invalid format" message displayed instead of picture
Could have still been hit by a surge. Take the back off of the TV and look at the main board were you connect your HDMI. See if it is scorched or components that blackened. Also check your DVD player on another set. Your DVD player could be the problem.
Apr 11, 2012 | LG Televison & Video
TREBA MI ZVUCNA KARTICA ZA FOXCONN 865G7MF
treba mi zvucna kartica za komp made by fujitsu siemens computers GmbH
Apr 08, 2011 | Car Audio & Video
Subwoofer stops working at times and will not work.have had it about 4 or 5 days just started doing it today
many pple have the same problem.... that subwoofer stops working sometimes when playing music or something else... I also faced the same problem .... I did the following things..
open your subwoofer. checked all connections for any loose contacts... and then check the wire of the main speaker.....
IF YOU FIND DIFFICULTIES IN OPENING OR IF YOU DONT KNOW MORE ABOUT THE INTERNAL PARTS OF SUBWOOFERS.. THEN DONT TRY TO OPEN IT.. YOU MAY CAUSE DAMAGE TO IT...IN THIS CASE :
GIVE YOUR SUBWOOFERS TO THE SERVICE CENTRE FOR REPAIRING...
Dec 15, 2010 | Onkyo SKW-200 Subwoofer
HT762TZ -hdmi off
Try new hdmi cable. Try different inpus on set. Try another known good signal source to determine is tv or souce device if at fault. If aother hdmi connector on set ok then replace main brd in tv, if none of the hdmi inputs work even with known good cable and known good signal sourse the replace main board in tv
Aug 29, 2009 | Panasonic DMR-EH57 HDD Recorder Player
I bought the DVD Home Theater LG HT762TZ and I would like to unlock the DVD player for the region number 4. Is it possible?
Yes it is and you will(or should) find it in your instructions. normally in the lock settings.
Jun 16, 2009 | Televison & Video
LG HT762TZ
try and do this is..On ur player make sure no CD in it press PAUSE then 314159 and then put all at 0..
cazadorlibanes@hotmail.com
Mar 27, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Regional Code
3602
1. Power on,
2. Press "Pause" ||
3. Enter "314159"
4. Press "0" (for region free)
5. Press "Enter"
... the 0 replaces the previous region number in the second line.
6. Press "Pause" ||
7. Power off.
Or
With the unit in DVD mode and the drawer open, key in "0" four times. A two line menu appears with "Edit Region:_" and "Region Code:x". Key in the required region (presumably 0) and press enter. Power off
HT762tz:
http://www.videohelp.com/dvdhacks/lg-ht762tz/9060
May 16, 2008 | Televison & Video
I'm not sure how to set up my LG HT762TZ home theatre system up properly. I have connected everything and made sure it is working properly, but i am not sure where to put the speakers and which way to put...
The rear speakers are meant to be placed at the rear preferrably overhead or at the bottom behind your listening area. Both speakers should be facing the sides. You can place your subwoofer anywhere as its sound is non directional. Don't forget to adjust its volume properly, the rear should not overwhilme the front/center sound. Happy Listening
Mar 27, 2008 | Audio Players & Recorders
Subwoofer Box Single Vented 10" Fits Dodge Quad Cab Durango Logo
46 people viewed this question
Top Obcon Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Obcon Vehicle Part and Accessory Expert? Answer questions, earn points and help others
