Question about John DEERE CONSTRUCTION LOG SKIDDER NIP 164
John deere 648giii service mannal
Will not take gear when move gear shifter out of park and towards the foward 1st the dash will flash a f327 code and will stay on intill you shut machine down and then restart it.alslo winch doesn't work
2 Suggested Answers
  • 19 Answers
SOURCE: I have a 1979 john deer skitter, when it's cold
the clutch pack on 1st gear is geating weak or the toque convertor is weak
Posted on Aug 15, 2010
John Deere 8330 PTP 524271.05
Try adjusting the linkage on the shifter the shifter may not be adjusted properly so the gears are not being fully engaged ,extend the linkage at least an inch or two (lengthen it)
Jun 23, 2015 | John Deere 2006 8330 69141
Reverse and 1st gear work but 2nd gear does not
might be a dumb ? but is the limiting screw still in the shifter? if not youve got a switch issue, here is a link to get a high/low switch for $11. to install, remove the shifter...1 screw in the back side and slide it forward. the high low is the one toward the rear.
good luck!
Dec 31, 2010 | Peg Perego John Deere Gator HPX Ride on...
Hi guys, my pride & joy JD7800.. WAS PARKED NOTHING WRONG.. WHEN STARTED DOESN'T GO INTO GEAR AT ALL.. SHIFTER WORKS BUT NO GEARS AT ALL, DASH DISPLAYS FAULT d1A, Please please help no money for...
Take the fuse out of #115 that will take you out of diagnostic mode. When you put it in reverse and it doesn't move then see what code comes up on the dash and follow up with me.
Dec 02, 2010 | John Deere 7800 Modern Farm Tractor Kit -...
My gator will work in reverse but not either foward gears please help
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
Sep 16, 2010 | Peg Perego John Deere Gator HPX Ride on...
The John Deere will go in reverse but will not move when in 1st or 2nd gear.
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath, you can order a new one here www.powerwheelsoutlet.com
Sep 04, 2010 | Peg Perego John Deere Gator HPX Ride on...
2nd gear won't work
Oct 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Goes in 1st and Reverse but not 2nd
Something you may want to check is to see if there is a "governor" for the 2nd gear. My 4 year old has a 4x4 similiar to this and the only two gears that worked were 1st & reverse until my husband had to unscrew a piece from the 2nd gear setting..check the manual or if you don't have one, look online through the manufacturers website. I hope this helps!
Feb 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
John DEERE CONSTRUCTION LOG SKIDDER NIP 164 Logo
213 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
