Question about Philips DVP3560 DVD Player
MY DVD PLAYER MODEL NO 3520 HANGS, CAN ANY ONE SUGGEST HOW TO START
My music player of 6300 is not working when i start it then my mobile hangs please suggest me
you need to subscribe to the the web for it to start or get a music card.
Jan 01, 2011 | Cell Phones
DVD Writer Model SH-S223 hangs when playing dvd.
Welcome to FixYa
Dear User
You have to Use a Lense Cleaner CD to Clean your Lense.Still same Problem Exist ti seems to Some Codec Problem.Try in Different Player.
Again Same Problem Send it for Repair/Replace....
Hope this Helped ...thanks for Connecting FixYa..
Oct 16, 2010 | Samsung SH-S223Q DVD-RAM Burner
I have a Curtis DVD Player model 1073 thaty has 6 speaker conections.The player will load dvd and cds but will start sticking and the dvd will go into a pause like scrambled mode, Not sure if worth fixing...
your laser is probably weak or dusty, cleaning the lens with a qtip, might remove some dirt/dust --if it continues to freeze and the discs themselves arent full of fingerprints etc.. than unfortunately the laser is bad and wouldnt be practical to replace
Aug 31, 2010 | Curtis Lifestyle DVD System
Hangs up
Chances are your Dvd player needs a good cleaning. Try running a Dvd cleaner disc through. This will most likely solve your problem.
Jul 01, 2009 | Sanyo DVW-6100 DVD Player/VCR
Compatibility
I have Vista and it works great it just see's it as another drive like a thumbdrive.
Feb 02, 2009 | Coby PMP-3520 (20 GB) Digital Media Player...
Dvd stutter
Hi lynnjunell,
I regret to hear you are having trouble with the Insignia® DVD player you purchased.
It is possible that the problem is with the DVD, even if it plays in other units. I would recommend first clean the DVD carefully to remove any residue or debris that may be on the disc. If this is still happening on multiple discs and cleaning does not help, I would recommend brining in the unit to your local Best Buy™ store to be checked out by the Geek Squad® precinct. If you are unable to locate your sales slip, the store may be able to assist if you recall some specific information surrounding the purchase. You may also call 1-888-BEST BUY (1-888-237-8287) for assistance in locating your purchase information for warranty purposes.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 17, 2008 | Insignia PD10135 Portable DVD Player
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
Hangs/ "wrong disc display"
yea take your DVD player to a repairman your micro could be your problem.good luck.
Apr 06, 2007 | Coby TFDVD7050 Portable DVD Player with...
DVD Player Problem
Here is a website just for your Cyhttp://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewforum&f=28berhome model. If you do not see an answer for your problem, ask and you shall receive. Good Luck
Jan 06, 2007 | Cyberhome CH-DVD 300 DVD Player
Reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Jan 29, 2006 | Panasonic DVD-LV70 Portable DVD Player...
Philips DVP3560 DVD Player Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
