Question about Pool & Spa
Malfunction of water heater
Heating starting before flow of water...
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Replace flow switch.
Posted on Dec 29, 2013
HE error code on samsung dishwasher?
This is usually a failed HEATING ELEMENT or HEATER RELAY. Disconnect power & remove the dishwasher from under the counter.
The HEATER RELAY is located on the right side of the D/W. A metal panel/shield (on the right side) must be removed to gain access for testing.
Testing the HEATING ELEMENT *can* be done from the bottom/front---but is easier if the D/W is placed on it's back---and removing the bottom cover/panel.
In many cases I have seen failed HEATING ELEMENTS or RELAYS on Samsung D/Ws---in homes which had an INSTANT WATER HEATER (AKA: Tankless Water Heater).
This type of Water Heater requires a minimum GALLON-PER-MINUTE of water flow---before it will *heat* the water.
Many dishwashers have a lower GPM flow rate than required---this results in NO HOT WATER at all during water fill.
The D/W heating sytem remains "on" for long periods of time---each time the D/W is used.
Eventually the HEATING ELEMENT or HEATER RELAY fails
Nov 20, 2016 | Samsung Dishwashers
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
I have fractional spa pump with 1000 watt heater. the spa was on but no water was in it while it ran overnight. did this burn the heat elements out of it and can I fix it?
It should be OK. These units should have a flow switch to prevent activation of heating element without water flow. Yes, heating elements can be relatively easily be changed if needed.
Dec 08, 2014 | Comfort Line Products Spa2Go Inflatable 4...
Why is my Bosch high flow 21e heater started working intermittently only heating water after tap is turned on and off a few times
Check gas pressures first especially on low setting. Ensure gas burner is clean get unit serviced if over 2 years old. Check or replace water flow sensor & clean inlet filter.
Jul 26, 2014 | Bosch & Tankless LP Hot Water Heater
Why is the flame on but water not heating
check gas pressure if correct check heat rise you might need to slow water flow down
Jun 17, 2014 | Jandy Legacy Natural Gas Pilot Light Pool...
Water heater
sounds like manual bypass stuck take out free up reinstall should be ok
Oct 21, 2013 | Pool & Spa
All of a sudden, our shower only produces cold water. When I turn the knob through it full range, it starts with cold as usual, but as I continue toward what used to produce ever hotter mix, it stays cold,...
I had the same problem. It was my heater/boiler this one runs my home heating and water. There's a 3 way gateway for central heating and hot water for shower etc. Probaly you got a aire bubble in there. Find the 3 way gateway and give it a knock, the bubble will disapear and the hot water will flow again. I'm sorry for my english but i'm Dutch.
dre
Nov 30, 2009 | Chrome Home
How does an electrial water heater work
it uses resistive heating elements that are encased in an electrical insulation and then covered with metal, like the cooking elements in a stove, or on a cooktop range. when electricity flows through them they heat up and get hot (like a light bulb filament wire glows) When the water reaches a certain temperature set on the thermostat, it opens the electricity,turns it off to the element until the water cools down past whatever temperature it is set at, and then it turns back on. That is why if too many people take a shower you will run out of hot water because cold water is always flowing through the water heater and when all the hot water is used, you have to wait for the heating elements to heat the water back up. To make sure it heats up quickly make sure all the HOT water faucets are off so that water isn't flowing through it and is just sitting there heating up. All work on the same principle.
Nov 09, 2009 | Electra 11-1/2" Water Heater
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
